05-29-2013, 08:21 PM | #1 |
Vintage 4x4s
WTB: 4x4 power steering pitman arm
For a K20. K10 may be the same? Not the same as a 2wd truck since the bore is only partially splined.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
05-29-2013, 11:00 PM | #2 |
Re: WTB: 4x4 power steering pitman arm
I will check to see if I have another NOS one.
05-30-2013, 05:32 PM | #3 |
I must have sold what I had. If I find one I'll PM you. Bump for YA!
06-09-2013, 10:08 AM | #4 |
Vintage 4x4s
Still looking
06-09-2013, 10:14 AM | #5 |
I think I have one, send me a pic so I can confirm we are talking about the same thing.
Posted via Mobile Device |
06-09-2013, 10:25 AM | #6 |
Vintage 4x4s
Here's the part id
06-09-2013, 10:54 AM | #7 |
Sorry brother, I have the steering arm not the pitman.
06-09-2013, 11:16 AM | #8 |
Vintage 4x4s
Thanks anyways for checking.
06-09-2013, 11:24 AM | #9 |
Carpe manana
Jud I have a pitman arm connected to the steering box of a 72 K20 frame here at home but it doesn't look like that in the diagram above...
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
06-09-2013, 01:02 PM | #10 |
Carpe manana
That on the K20 box also appears identical to that on my 72 K10. Let me know if I can help you out...
06-09-2013, 03:35 PM | #11 |
Vintage 4x4s
Pete, that was just a generic diagram. The correct one will be partially splined and have a little twist at the end. The one you have is probably correct. What do you want for it? Also how much for the box and arm combo?
Jud
06-09-2013, 03:55 PM | #12 |
Carpe manana
PM sent
06-10-2013, 07:31 AM | #13 |
Parts are the same K/5-K/20. Your sector shaft drops out the bottom and the pitman swings side to side,right? Check for ear on splines. I had a wandering problem on my present '72 and it turned out to be the pitman arm splines wear worn
06-10-2013, 01:45 PM | #14 |
Vintage 4x4s
the pitman arm swings front to back on my k20s since the draglink is parallel to main frame rails. correct on the sector shaft being vertical.
