Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 05-30-2013, 02:00 AM   #1
Arekusu
Arekusu's Avatar
Weights of truck parts (some 1964 specific)
Well I'm finishing up my build and decided to weigh stuff for others to reference. Maybe it'll help someone with it being in the interwebs now. Feel free to add weights of post your variations so we can calculate a delta. Used a digital bathroom scale. Here's the list. Weights are in pounds. "PC" = powder coated
Porter Built L trailing arm "PC" - 18.7
Porter Built R trailing arm "PC" - 19.3
Porter Built trailing arm lower tie / lateral connector "PC" - 5.8
Porter Built Trailing arm cross member with adj. brackets "PC" - 22.4
Porter Built coil over upper mount cross member "PC" - 5.8
Porter Built front sway bar "PC" - 22.6
Porter Built panhard bar with frame mount "PC" - 7.5
Porter Built Front upper control arms "PC" (bare, no bolts, bushings, etc.) - 4 ea.
Porter Built Front lower control arms "PC" (bare, no bolts, bushings, etc.) - 15.6 ea
Stock trailing arm with bushings and bolt - 24.2 ea
Stock trailing arm cross member - 24.4
Moroso front springs - 15.8 ea
292 I6 stock front springs - 11.3 ea.
Rear Spring 4" drop - 8.7 ea.
Front Spindles "PC" (bare) - 23.8 ea.
Front 5x5 rotor w/ lug nuts, bearings, dust cap - 27.9 ea.
Front Caliper from 5x5 set up with pads and mounting bolts - 12.6 ea.
Inner and Outer tie rods with connection sleeve - 3.8
3/4 ton 1985 C-10 sway bar with bushings - 22
Inner fenders "PC" - 16.6 ea.
Front right fender, primed, painted, 2 coats clear with rubber under coating on inside - 12.1
Front left fender, primed, painted, 2 coats clear with rubber under coating on inside - 12.4
Rear right stepside fender. primed, painted, 2 coats clear, rubber undercoating inside of fender - 27.5
Rear left stepside fender. primed, painted, 2 coats clear, rubber undercoating inside of fender - 23.7
Drivers "step" with "L" bracket attached, fully painted w/ undercoating - 8.2
Pass. "step" with "L" bracket attached, fully painted w/ undercoating - 8.2
Cowl cover / windshield wiper linkage cover - 3.9
Master Cylinder and Booster (no fluid) - 12.6
CCP transmission brace - 6.1
Stock from 64 front glass - 23.1
Stock from 64 small rear glass - 7.1
Arekusu is offline   Reply With Quote
Old 01-03-2015, 04:33 AM   #2
moggey01
Re: Weights of truck parts (some 1964 specific)
Cool glad somebody else had some info. My weights are real close to yours on stuff. My truck is a 68 though.
moggey01 is offline   Reply With Quote
Old 02-02-2015, 01:10 PM   #3
skeeterbug
skeeterbug's Avatar
Had my stock front bumper(22.4#) and hood(68.43#) off my 71 last week as i am replacing both with fiberglass units i sourced from Shakedown racing in LIndale, TX. New glass bumper weighed in @ 4.6#'s....have not received the glass 6" pin on hood yet though. Should be here any day now, bumper looked pretty good too!
'71 LWB c10-"WORK" in progress
385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall
2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better)
2013 best 7.39
2014 best-7.38
New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage
skeeterbug is offline   Reply With Quote
Old 02-25-2015, 03:57 AM   #4
moggey01
Yeah. The bumper is nice. I have one also. Pin on hood is about 13 lbs. Mine is a stock style hood..for now.
part weights, porterbuilt, weight
