06-02-2013, 04:47 PM | #1 |
Needed... Plans for 67-72 cab jig or rotissery
A while back somebody on here had plans for a 67-72 cab rotisserie or Jig... I need to get a copy of those... Thanks... Dan
06-02-2013, 10:26 PM | #2 | |
Re: Needed... Plans for 67-72 cab jig or rotissery
2 4x4x10 one on each end 2 2x4x4 one on each end bolted to frame. 2 5/8x10 bolts on each end. 4 5/8 flat washers or 4 2x2 flat washers 4 5/8 nuts I planted the 4x4 2 1/2 ft into the gound at each end of the truch frame Then I drill a 3/4 hole thru the 4x4 at the desire height you want the rotisserie. I drilled the same size hole thru the 2x4 and insert the bolt thru both holes. Double nut the bolt to keep it from turning out. You can go to my page and see the rotisserie at work. This will only work if you are doing it outside where there is no concrete. I don't know if this is what you are looking for. Gdavis
Check out Patches Cars I owned in the past. 1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev 1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS 1967 Buick electra 225 1995 Harley Davidson bager What does not kill you will make you stronger 1968 c10 short wheel base stepper |
