![]() Join Date: Nov 2008
Np205/350TH Transfer Question
I needed to remove my transfer case.
to fix the pivot shifter bolt that broke. So I'm getting ready to reinstall. So my question is, does the transfer case have is own lubricant as in do I remove a plug like a diff. cover and pour in fluid or does it get/use transmission fluid from the transmission? Am I asking the right question?
1970 ![]() 1971 ![]() 1971 ![]() 1972 ![]() 1972 ![]() 1999 ![]() |
![]() Join Date: May 2007
Re: Np205/350TH Transfer Question
They need their own lube. Remove the higher of the two pipe plugs, and fill with 80/90 gear lube.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
Thank you.
