06-13-2013, 02:48 PM | #1 |
Hedman 69010 Installed pics
There have been lots of header questions lately. I went with Hedman #69010 from Jegs. They were around $200 fron JEGS. I painted with VHT, but didn't cure them right, so thats why they are peeling in places. Thet clear great and have more room than the pic angle makes it seem at the heater box and motor mounts. You will need shorter plugs, I used NGK UR5 on my 383. Truck is an automatic with column shift. The pipes are completely tucked in the frame, which was essential for my bagged truck. They have a ball and socket type collector, I eventually had to put jam nuts on to keep the collector bolts from coming loose. Here are some pics, I left them big to show more detail. They bolted on with no other modification, buy driver side plugs need to be in first (at least with the NGK's.)
=MATTHEW 69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN 2003 Chevrolet Z71 Ext. Cab 1995 Cavalier gas saver! |
06-13-2013, 02:49 PM | #2 |
Re: Hedman 69010 Installed pics
more pics
06-13-2013, 04:27 PM | #3 |
You rock, thanks for the post!!!
06-13-2013, 11:51 PM | #4 |
Glad to help!
06-14-2013, 08:51 PM | #5 |
Thanks for the post. Im going with those too.
Rob
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=578272 https://www.instagram.com/fb_garage/ |
08-12-2015, 12:30 AM | #6 |
Do you have your motor in the L6 or V8 position? Thanks for posting pics.
08-12-2015, 12:41 AM | #7 |
So to do a plug change the one header will have to be unbolted from the head?
"You can take the man out of PA, but you can't take PA out of the man" |
08-12-2015, 01:18 AM | #8 |
08-12-2015, 11:11 AM | #9 | |
better clearance for the dist. but worse if youre running electric fan assy. ask me how i know its a tight fit. those headers tuck nicely in the frame. when using the paint you used, (VHT) whats the curing procedure?
1967custom |
08-19-2015, 11:47 AM | #10 |
Michael, i painted, let dry, oven at 450 for 45 min. Came out well imo, just make sure to prep the areas well otherwise like anything, it will come off
08-19-2015, 11:48 AM | #11 |
Heavy d, i did not have to remove either manifold, it is tight but use a 5/8 wrench...
10-10-2015, 11:46 PM | #12 |
10-11-2015, 01:57 PM | #13 |
I have had great results with vht. The key is prep sand blasting is the best way to ensure a great bond
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
