Old 06-17-2013, 04:29 PM   #1
NewType72
NewType72's Avatar
Exclamation 67-72 throttle linkage bracket
I'm swapping to a vortec base motor 96-2000 or so in my 72 chevy c-10 and I'm curious what exact throttle/kickdown bracket ill need to be set up correctly it'll be a 350/th350 setup that I have now I'm just updating the motor and keeping stock cables.
I hear lokar is good but what exactly do I need?
Thank you
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 06-17-2013, 10:02 PM   #2
NewType72
NewType72's Avatar
Re: 67-72 throttle linkage bracket
Any ideas out there?
- Dylan
(209)-985-7721
Old 06-18-2013, 12:09 AM   #3
Captainfab
60-66 Nut
There very well could be other manufacturers of a throttle cable bracket, but this one is the only one I know of specifically for the Vortec heads/intake.
http://www.summitracing.com/parts/edl-8032
Old 06-18-2013, 12:32 AM   #4
NewType72
NewType72's Avatar
well now that would be perfect but how exactly does that hook up?
It's better to mount off the intake opposed to the the rear of the carb right?
- Dylan
(209)-985-7721
Old 06-18-2013, 09:31 AM   #5
68gmsee
Active Member
68gmsee's Avatar
Probably doesn't matter. Not much stress exerted by throttle/transmission cables to cause a problem.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 06-18-2013, 10:03 AM   #6
NewType72
NewType72's Avatar
Very true in that perspective ill have to look around a bit more and see what everyone's running
- Dylan
(209)-985-7721
bracket, carb, kickdown, motor, throttle
