06-19-2013, 12:02 PM | #1 |
Hydraulic pedal assemblies 1 with hydroboost, one with vacuum
BOTH PEDAL ASSEMBLIES HAVE BEEN SOLD! I have came up with 2 more of these. One is for hydroboost brakes and one is for vacuum brakes. Hydroboost is on the left. This is higher priced than most you will find for sale. It is also nicer than all of the other out there These have brand new bushings in both the clutch and brake pedals. The result is smooth pedals with very little play in them. Price is only marked up according to my cost on bushings($24) and having the pedals welded. Many other selersl post pedal assemblies for sale. Most if not ALL have wear to the pin that the clutch master cylinder attaches to. None of my pedal assemblies have this issue. I only sell the best quality available. Mine have all been professionally welded, ground and then filed smooth to work as new. When these pieces get worn it causes the pedal to not engage the clutch properly thus make it hard to go into gear. Even if you don't buy from me, do yourself a favor and ask other sellers if their pedals have this problem. Price is $250 EACH not including shipping. I also have a complete hydraulic conversion if needed.
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. Last edited by 1774btcrew; 06-01-2015 at 10:26 AM. |
06-19-2013, 12:15 PM | #2 |
Re: Hydraulic pedal assemblies 1 with hydroboost, one with vacuum
how much for complete hydrlyic conversion? and do you have any tilt floor shift colums for a 80 gmc?
1969 chevy camaro Z28 #matchin Factory 4wheel disc 1969 chevy cst10 big block overdrive 5/7 drop dog dishs 1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s 2004 gmc sierra dually 4/4 lowering daily driver |
06-19-2013, 12:22 PM | #3 |
I would want $470 for a complete set up(pedals, slave cylinder, clutch master cylinder and bell housing, reservoir and lines. I do have a rebuilt tilt column for the 79-83 floor shift trucks but it is expensive at $350FIRM as I have a lot of work into it and they are relatively hard to come by. It has been completely disassembled and includes the key. It is ready to go.
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. Last edited by 1774btcrew; 10-20-2014 at 07:46 PM. |
06-19-2013, 12:23 PM | #4 |
how much would shipping to 28214 be? to a business if that makes a difference
06-19-2013, 12:28 PM | #5 |
On the hydraulic assembly or the column? They would need to be shipped separately if you wanted both as the length of the column doesn't mesh with the size of the other items. I will send you a PM with my email address.
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
06-19-2013, 12:29 PM | #6 |
im interested in the conversion and the column depending on shipping
06-19-2013, 01:31 PM | #7 |
It is going to be $20 shipping on the column and $27 on the rest of the stuff. If for some reason it is less I will refund the difference.
06-20-2013, 09:44 PM | #8 |
Sending PM
06-23-2013, 09:42 PM | #9 |
Suburban Hick
Do you still have the hydroboost pedal set?
Mathew 1947 Chevy 3600 1951 GMC 100 1969 Chevy C-10 396/500hp TH400 lowered 4" 1968 Imapla Custom 396/325hp TH400 "Grandmas Car" 1976 Crew Cab 4x4 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=488505 1978 Chevy K-10 454 1983 S10 4x4 "Bumblb" (Grandpa's truck) 1993 Chevy S10 V8 conversion 1990 Ford Probe Gt 1992 Dodge W-150 "Old Man's Truck" 1992 Pontiac Grand Prix SE 1992 Mercury Grand Marquis-Mercruiser 2000 Ford F150 (Currently my mother drives this) 1946 Farmall H with Stan Hoist loader 1965 John Deere 110 1961 Wheel Horse " Rat Tractor" |
06-24-2013, 11:58 AM | #10 |
I do still have a hydroboost pedal assembly. I will send you a PM with my email address.
01-26-2014, 01:31 AM | #11 |
ttt
02-14-2014, 11:18 AM | #12 |
Can a vacuum booster be used on the hydro-boost setup? I need a hydraulic clutch pedal set, but don't really want to run hydro-boost
74 C10 LWB 350/T5 Dropped on 20's Soon to be Bagged and Injected 84 C35 Crew Cab Dually. 454/400 Dropped a lot. Instagram: mmmdropp |
02-14-2014, 01:56 PM | #13 |
I actually have pedal assemblies for either hydro boost or vacuum brakes. Whichever you need.
02-15-2014, 03:39 PM | #14 |
I know the pieces fit
How are they different? I have a set of pedals for a manual trans swap and might not have the right ones.
02-15-2014, 03:42 PM | #15 |
The location of the pin the brake rod mounts to is in a different place on them and hydro boost pedal assemblies also have a return spring. The hydro boost pedal assembly also only has 2 mounting studs
06-30-2014, 07:15 PM | #17 |
6>8 Plugless........
Do you have any hydraulic pedal assemblies for a hydro boost? I'm looking for a set for my 76. Thanks Ryan.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
07-03-2014, 10:50 AM | #18 |
I just picked up a couple more pedal assemblies over the weekend. Is your truck already manual trans with Hydroboost?
07-03-2014, 03:09 PM | #19 |
No sir, currently the cab is set up for an auto with hydro boost. I won't be using a GM trans though. I'll be using a dodge NV4500.
07-07-2014, 04:44 PM | #20 |
I came up with a perfect one today. There are some out there that are listed for less than mine but most if not all have a lot of wear to the clutch pedal wear the rod attaches for the clutch master cylinder. This causes the slave cylinder to not push the shift for as far making it harder to get into gear.
07-07-2014, 07:20 PM | #21 |
How much shipped to 50169?
07-07-2014, 08:30 PM | #22 |
07-10-2014, 06:40 PM | #23 |
I had 2 different people contact me on these. They are priced less than what these sell for on Ebay and in way better condition than them as well. The sellers fail to mention that it is worn where the clutch master cylinder attaches to the clutch pedal. Mine do NOT have that defect/problem. They are ready to install and will work properly. Even if you do not buy one from me be sure to check with the sellers about the condition of them.
07-10-2014, 08:24 PM | #24 |
I'm going to have to pass for right now. I had a couple other items I spent my truck allowance on that I wasn't expecting.
07-22-2014, 10:24 PM | #25 |
I'm looking for hydraulic clutch/ pedal assembly for vac assist brakes. Anymore available? If so price and shipping to 21122. Yeah I'm on the wrong coast.
