meowMEOWmeowMEOW
Mix of 66 stock and ls swap leftovers.
All prices + shipping, will combo some stuff. Offers welcome but be reasonable. Located in 53217, Milwaukee WI
64-66 stuff Fuse panel, $10? ![]() Stainless steel full length true dual exhaust for a 66 short step with a small block. Exits out the back. Tig Welded stainless, made for p.o. of my truck. Designed for use with bullet style mufflers (14-18") . Because of the size and weight, I'm open to offers, but keep in mind shipping costs if you are out of state. I can get more pics ![]() ![]() ![]() Stainless gauge panel. Circle punched for a 3-3/4in (96mm) gauge in the center. Fits into the back of the gauge bezel with screws and washers, or epoxy/glue it. Its homemade and not perfect, but works for what it does. I have one in my truck, made 2. Check my build for how I used this peice. $15? I guess idk ![]() LS/LQ4 Swap leftovers/performance stuff LQ4 pushrods 7.4" all in good shape, no damage. $25 full set or $3 each loose ![]() LQ4 stock oil pan, windage tray and pickup tube. All in good shape, and I think I have a full set of bolts for the oil pan which will come with if you want. No damage, just some light overspray, as it was painted with my block. $45 ![]() Jumper harness to extend TAC Module and pedal. Came with my harness, but I didn't need the extra length. $30 ![]() Injector clips for Multec II Injectors, no pigtail, full set $10 ![]() A set of LQ4 stock injectors, all in good shape and working $35 A few extra step up diodes (the ones you use to run a regular tach on an LS swap) $3 shipped An extra set of AN to Push-to-Connect fittings (3/8 and 5/16 old design) make offer 2 Sets of Hose bard to Push-to-Connect fittings in 3/8 and 5/16, $5 set B&M Floor shifter for 4-speed Automatics....customized for use in 60-66 truck Includes bracket, NSS and hardware. $95 obo This shifter has a ~30* bend on the shifter arm to provide a better hand position and leg clearance when installed in a 60-66 truck. I made a removable and changeable shifter arm extension, which uses the same threading as the original handle to allow for a changeable length, throw and hand-height (included). It also allows you to use the stock T shifter handle (included but not pictured), or any other shifter handle tapped for the stock style threading. This was in an ls-swapped truck with a 4l80e. ![]() ![]() ![]() ![]() ![]() ![]() A few handfuls of air ride fittings, mostly 3/8 and 1/2. I've got 1 or 2 of 8-10 different fitting types.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
meowMEOWmeowMEOW
Re: Mix of 66 stock and ls swap leftovers.
meow, this stuff is making my garage look small.
meowMEOWmeowMEOW
Bump
meowMEOWmeowMEOW
SUMMER HEAT WAVE....buy things while your locked in the air conditioned house!
meowMEOWmeowMEOW
meow?
Say, do you still have that fuse block?
That's the thing about a Chevrolet, no matter how they look, whether it be a trailer queen or a good ol' used farm truck, no other truck on the road will always look that damn good wearing a Bowtie. |
meowMEOWmeowMEOW
I think I do, I'll stop by the other garage tomorrow or saturday and I'll let ya know.
Alright, thank ya much friend.
meowMEOWmeowMEOW
Hey Dillon, I found the fuseblock in the shop if you still need it.
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Those elbows on the exhaust pipes where they would bolt up to the collectors, do they drop enough to clear the underside of the cab if using ramshorn, or were these built for headers?
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#11 | |
meowMEOWmeowMEOW
When bolted up, they drop from just below frame height, angle back (like the cab wall/footwell does). It tucks under the rocker area sorta. If you look at the early pages of my build, you can see it installed and the headers it was on. Its complete tip-to-tail, sans the bullet mufflers/resonators you would want to install. The exhaust will fit a long or short bed truck, because the muffler is positioned just aft of the doors, so you can use as short or as long of a muffler as needed to fit the frame you've got. It was on my 66, and we "eyeball" fitted it on a friends modded 68 (ran a trailarm arm/2 link)
