06-25-2013, 02:13 PM | #1 |
Turns farther to the right
I changed steering gear (and all suspension and steering parts) this weekend.
The truck now turns much farther to the right than it does to the left. It also drags the drivers front tire on tight turns in the parking lot. what did I screw up? Is this something fixed by an alignment? |
06-25-2013, 02:22 PM | #2 |
Cluster King
Re: Turns farther to the right
I would not worry about it but get it in for alignment as soon as possible. You have probably got the steering box off center somewhat and that will cause you toe to be off.
Try counting the turns of the steering wheel lock to lock and then put the wheel in the center. For example, turn the steering wheel all the way to the left then count how many full turns of the wheel it takes to go all the way to the right. If it is 4 turns, then your center would be 2 turns. If you have it centered at 2 turns, look at the position of the tires, they will probably not be centered. You can correct this by adjusting the tie-rod sleeves. I would just let the alignment shop do it since you need to have them align it any way. Good luck. |
06-25-2013, 02:23 PM | #3 |
Make sure your drag link isnt upside down. I did it with mine and I almost didn't realize it
1995 s10 blazer 4.3 1967 c10 350/350 fleet short 1993 s10 blazer 4.3l 4l60 RIP 6/20/14 2000 mercury sable Thats a how I roll |
06-25-2013, 02:27 PM | #4 |
strangley its only 3.5 turns lock to lock. this is a reman gearbox from cardone. I thought factory was 4 or more turns lock to lock.
anyway... I need to find a good pic of the drag link. I wasnt sure on that when I was putting it back in but I figured if everything connects it must be right. But I have been known to be on the wrong side of the 50/50 chance more than once. parts store guy is saying the pitman arm is probably off by a spline. |
06-25-2013, 02:35 PM | #5 | |
Cluster King
Get your steering wheel centere(1 3/4 turns) and see where your tires point. Did you replace tie rods and sleeves on both sides and are the adjustments equal left to right? |
06-25-2013, 02:40 PM | #6 |
i replaced tierods and ball joints and adjusting sleeves, pitman and idler. The tierods are not equal side to side. I had to do some adjusting. Im completely maxed on the drivers side.
the pitman does have notches at 90 degrees. so I think ill center the wheels and then unhook the pitman from the gearbox. Spin the steering wheel to the left until it matches back up with the next notch and see what happens. |
06-25-2013, 02:55 PM | #7 |
Pitman arm won't matter, if it was off nothing would fit. I would center the wheels and the steer box with the center link still connected and also with the tie rod ends removed at the wheels. Then adjust them to fit the hole. This should get you close to get to the alignment shop
06-25-2013, 03:57 PM | #8 |
I did a disc conversion and steering box at the same time. It was a mess to get it all back and happy but this worked for me. Also mine is 2wd so maybe easier?
Centered the steering box between locks with drag link installed. Set the front wheels with full weight on them as centered as I could with a tape measure measuring to the frame then to each other. Put the tie rods together and installed them without moving wheels or steering Then tweaked each tie rod evenly until the steering wheel shaft center was straight up. Then drove to the alignment shop.... I was 1/8th off on toe and .5° on caster. (Camber was another story due to new spindles.)
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 Last edited by Longhorn 70; 06-25-2013 at 04:11 PM. |
06-25-2013, 04:12 PM | #9 |
I would verify pitman arm is centered first.
06-25-2013, 04:16 PM | #10 |
thanks for the tips guys. The more I think about it the more I decided im sick of being under the old girl right now. Spent the last 4 days working on the steering/suspension.
sooooo.. AAA is on the way to pick it up and drag it to the alignment shop. I talked to the old guy this morning and he said he would work it all out for me I feel kind of gimpy for giving up but oh well. |
06-25-2013, 04:39 PM | #11 |
The thing to do when you are replacing parts like that is to make the new assembly as close to the take off as possible that way you don't get shifts and stack-up throwing you off. If you are reusing some parts I just use a soda case flat or some other cardboard and mark the inner and outer tie rod centerlines with a marker for each side then I can build the replacement up without trying to measure moving maybe greasy parts. Then if my toe is in or out a bit iti is easy to dial it back to close for a run to the alignment machine. Finally if there are assemblies that might be handed a spots of spray paint or wraps of tape can easily id the left tie rod assm and the left end of the center link. Mark them in place and take a picture when in doubt.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
06-28-2013, 05:31 PM | #12 |
well the alignment shop gave up. its aligned but still turns to far to the right. He thought maybe a bad steering box but I cant see that.
He said he pulled the pitman and centered the gear box and put the pitman back on and it still does it. Anybody got a picture of the drag link? It was mentioned maybe it was upside down? |
06-28-2013, 05:50 PM | #13 |
from some pics i found online it looks like the draglink should flip UP on the ends. correct? Im going to go get the truck and will see what I did to mine...
06-28-2013, 06:19 PM | #14 |
When looking straight on, the pitman arm and the idler arm mounting bosses should be pointing forward and slightly down. That's the orientation on my 72 with power steering. Looks like the shop maybe verified the steering box is centered, if that's the case and the tie rods are about the same length zerk to zerk and the relay rod is correctly orientated then you have a bad steering box. I would remove the pitman arm and verify center before returning it. If the tie rods are different length I would disconnect the pitman arm (completely) and idler arm, then with the wheels pointed straight forward adjust both tie rods to about the same keeping the wheels straight, then verify box is centered, then reattach idler and pitman. If its still off you have a bad box. To get the alignment close to get it back to a shop, just get a tape and measure from center of each tire and find/mark the center on the front crossmember before taking it apart. Good luck,
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
06-28-2013, 06:41 PM | #15 |
i dont think the centerlink can go in upside down because the taper on the holes would be wrong and youd never get the nuts on.
he mentioned a bad steering box as well. bah humbug. Its so hot today. Im going to wait till the sun gets lower and try your suggestion lee. Oh and he said hed realign it for me after I swap the box for free. |
06-28-2013, 08:48 PM | #16 |
SO I saw another of your posts where you mention the tie rod nuts should face out. Mine face in.
so looks like you cant put it in upside down but it CAN go in backwards. And the one image I could find of mine before I took it out looks like is opposite of the way it is now. so i hope I dont beat my grease boots to death taking it out tomorrow. going to need to get the !@#$$%^#% pickle fork and pitman puller. arghhh |
06-28-2013, 09:05 PM | #17 |
Might wanna use a puller on tie rods to save boots.
06-28-2013, 09:33 PM | #18 |
Not sure where you got those pictures but that relay rod orientation is back words. The mounting bosses for the pitman arm are tilting up and pointing backward.
06-28-2013, 09:49 PM | #19 |
First 5 are the truck now. Last pic is of the truck before I took it apart.
So its backwards. I wonder if that is the sole cause of the issue. I guess that's why they call it steering geometry. Posted via Mobile Device |
06-28-2013, 09:53 PM | #20 | |
06-29-2013, 07:59 PM | #21 |
made some progress today. I flipped the centerlink around and adjusted the tierods so they are close to the same length. Seems to turn left and right the same amount now
still having an issue with the tire dragging on a tight turn. I think just on the left side. Not sure what to look at now. |
06-29-2013, 08:03 PM | #22 |
Great news! Verify it's turning near the same side to side and then take it to an alignment shop, it's ready to be dialed in. Good job.
06-29-2013, 08:07 PM | #23 | |
Cluster King
You will still get a little scrub on the tire when turning full lock. That is normal. |
06-29-2013, 08:15 PM | #24 |
yep laces out!!!! as ace ventura once said!! lol
yea the nuts are on the outside now. so dragging on full lock is normal? Sounds like I just need to take her back to the alignment shop and have them button it up. I measured from top shock mount to caliper bleeder at full lock on both sides and its within an inch on both sides. (i think) Ill confirm that tomorrow. Dang hot out there today. wife thought I was crazy. thanks for all the help guys!! |
06-30-2013, 11:47 AM | #25 |
Who's got steelies?
When I converted from manual to power steering, I noticed the same thing as you-would turn to the right slightly more than the left. I never had the tire drag problem.
My box came from O'reilly's. I can't remember if it was the same way with the manual gear or not.
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
