07-08-2013, 09:01 PM | #1 |
3 inch spacer
If i run a 3 inch wheel spacer on a 4x4 blazer ,can i have normal hub caps ? thoughts welcomed !
07-08-2013, 11:10 PM | #2 | |
Re: 3 inch spacer
I won't venture an opinion about running a 3" spacer... Joanne |
07-09-2013, 09:57 AM | #3 |
SKINNY TIRES RULE!
Re: 3 inch spacer
Sounds dangerous.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
07-09-2013, 10:45 AM | #4 |
Re: 3 inch spacer
1.5" is all you need to remove the stagger from the rear axle being shorter...
Also, spacer is bad, adapter is better, adapters bolt to the existing studs and then have their own studs that the wheels bolt to. Always be sure to remove the wheel and re torque the adapters to the hubs just like you'd check the outside lug nuts. |
07-09-2013, 04:16 PM | #5 |
Re: 3 inch spacer
Thanks!!!
07-10-2013, 01:49 PM | #6 |
Registered 1971 K5
Re: 3 inch spacer
[QUOTE=70-K5;6164109]1.5" is all you need to remove the stagger from the rear axle being shorter...
Also, spacer is bad, adapter is better, adapters bolt to the existing studs and then have their own studs that the wheels bolt to. Always be sure to remove the wheel and re torque the adapters to the hubs just like you'd check the outside lug nuts. [/QUOTE 70-K5 Is that a 2 piece adapter? I planned on getting some myself but had not seen the type you have. How do they attach to the wheel studs onto the rotor or drum? |
07-10-2013, 04:10 PM | #7 |
Re: 3 inch spacer
Just googled the image to illustrate the difference between adapters and spacers. Spacers are typically 1/4" or so for minor adjustments for little car tires.
07-10-2013, 04:47 PM | #8 |
Re: 3 inch spacer
Adapters not as bad as they sound just hard on bearings and hubs and knuckles and depending on how much adapter you use and how big your lock out is you may get away with a factory hub cap with no hole
07-10-2013, 04:48 PM | #9 |
Re: 3 inch spacer
Ps: Do not use a three inch spacer
only an adapter spacer would be dangerous |
07-10-2013, 04:49 PM | #10 |
Re: 3 inch spacer
Duallys have been running a front spacer/adapter for years on the front of them
