Old 07-10-2013, 09:48 AM   #1
dirish
dirish's Avatar
tranny cooler suggestions( 700r4)
Anyone w/ the 700r4 running no cooler?
Installing soon lining up parts, suggestions or experiences
Good or bad please. Running a mild 350. Thanks!
dirish is offline   Reply With Quote
Old 07-10-2013, 11:05 AM   #2
slow-1
slow-1's Avatar
Re: tranny cooler suggestions( 700r4)
I have run a 700r4 for 11 years without an additional trans cooler (just the radiator), I occasionally pull a 4000 pound boat to the coast, 400 miles round trip...still works like it should.
slow-1 is offline   Reply With Quote
Old 07-10-2013, 11:53 AM   #3
dirish
dirish's Avatar
Thank you for the info! Truck may get 150 miles a month if that.
Maybe more with new tranny. Goes in shop tonight. This was a
Last minute thought.
Old 07-10-2013, 03:47 PM   #4
chopnchaneled
chopnchaneled's Avatar
Betting you will be driving it more
wait a minute, what ratio is your diff?
I don't think we get smarter as we get older. We just run out of Stupid things to do.
chopnchaneled is offline   Reply With Quote
Old 07-10-2013, 04:26 PM   #5
dirish
dirish's Avatar
3.73
Old 07-10-2013, 05:39 PM   #6
slow-1
slow-1's Avatar
You will definately like it.
Has anyone come up with a better way to lock the converter when not in OD? I have a little toggle switch under the dash that works great, but I am always scared I will forget to turn it on when towing.
Old 07-10-2013, 06:00 PM   #7
dirish
dirish's Avatar
I believe its built to lock up in fourth only. Has one wire, goes to
A 12volt power. He said i could have a switch if i wanted, but not necessary.
I wont be towing either. Im not a mechanic, so i may have miss spoke somewhere.
done alot of reading, and listening, still learning.
Old 07-10-2013, 06:07 PM   #8
67anthony
Run mine thought the radiator works fine.
67anthony is offline   Reply With Quote
Old 07-10-2013, 08:29 PM   #9
heathbirkendahl
So the toggle switch is optional if not towing?
I will not be towing. Won't say never but I don't own a trailer or a boat. LOL
1971 C/10 - Orange & White
2009 GMC 1500 - Lowered 3/4 22' KMC Slides
heathbirkendahl is offline   Reply With Quote
Old 07-11-2013, 06:39 AM   #10
dirish
dirish's Avatar
I believe its how it is built, mine will lock in fourth, which is ok
After a 3sp tranny for so long. Will help my rpms stay lower. Im looking
For engine life as well as miles. But ask a tranny man to be sure.
I dont always grasp what my tranny guy says. Truck is At shop as of last night!
Let the games begin.
Old 07-11-2013, 09:32 AM   #11
slow-1
slow-1's Avatar
The way mine works (sounds the same as the others) is that the converter locks up automatically when it shifts to 4th (OD), if I put the gear selector in 1,2,or 3, I flip the toggle switch that locks up the converter. I only shift to 3rd when I am towing my big boat to keep the revs up a bit, just works better. You may use 1st or second in a traffic jam or cruisin the strip at a rod run (but you probably dont need to lock it up then).
One time I forgot to flip the toggle towing the big boat (4000#) and the trans got hot FAST, flipped switch and it went right back to normal.
Wiring the toggle is very easy, fuse box to toggle to plug on trans.
Old 07-11-2013, 11:02 AM   #12
ironroad9c1
Master Hater
Always put the biggest cooler you can find, for every 20 degrees you lower the trans fluid temp, you double the life of your transmission. problem with heat in a transmission is it hardens the rubber seals, then you get pressure leaks and then it starts slipping clutches and goes to hell from there, never hurts to install a cooler. the newer stacked type coolers work much better than the old fin and tube types.
1997 C1500 ECSB 4.3/NV3500 8.5 3.42
"This evening, all of you bleeding hearts... why don't just go ahead and hug yourself for the next 20 minutes or so, because there's a really good chance you're gonna be offended".- Captain Owen Honors
ironroad9c1 is offline   Reply With Quote
Old 07-11-2013, 01:38 PM   #13
Katrina/10
Katrina/10's Avatar
What about the old story, "Don't tow in overdrive with a 700R4?" Is that true?
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 07-11-2013, 01:45 PM   #14
Longhorn 70
Longhorn 70's Avatar
That is how I roll.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 07-11-2013, 02:32 PM   #15
dirish
dirish's Avatar
I've always been told, no OD when pulling weight.?
Old 07-11-2013, 03:27 PM   #16
Katrina/10
Katrina/10's Avatar
Originally Posted by Longhorn 70 View Post
That is how I roll.
So you are towing in overdrive with the converter locked? I have one of these transmissions in my 71, and want to know if I can get away with that.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 07-11-2013, 03:44 PM   #17
Longhorn 70
DON'T tow or haul heavy in Overdrive is how I roll.
Old 07-11-2013, 04:01 PM   #18
Katrina/10
Katrina/10's Avatar
Got it, thanks.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
350 sbc, 700r4, transmission cooler
