Old 07-12-2013, 03:12 PM   #1
72tutone
Coil Spring Plates
After cleaning up my frame I noticed right where the spring perch mounts to the plate on the frame, there is some rust accumulating.
Is it safe to remove the rivets and clean up and bolt back with some grade 8?
Any particular bolt size that is good for stock rivets? I hear 10mm might work?
72tutone is offline   Reply With Quote
Old 07-12-2013, 03:14 PM   #2
vegadesign
vegadesign's Avatar
Re: Coil Spring Plates
should be just fine with grade 8 bolts, from the pic tho looks like they are kinda sagging in the middle?
"its not a hobby, It's a Lifestyle"
bagged and soon to be bodied 70 longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=564028
vegadesign is offline   Reply With Quote
Old 07-12-2013, 03:29 PM   #3
72tutone
Yea that is rust in the middle that is making them sag.
I wanted to grind off the rivets, clean em up and bolt em back in.
I hear 10mm or 7/16 will do the trick? Any ideas as to which will fit better?
Old 07-12-2013, 04:50 PM   #4
vegadesign
vegadesign's Avatar
more than likley 7/16
Old 07-12-2013, 08:18 PM   #5
67c10rustbuket
67c10rustbuket's Avatar
I just went out and measured a rivet hole and it measures .41". I have been drilling them out to 7/16" and installing 7/16" (.4375") grade 8 bolts. A 10 mm bolt converts to .3937" so it may be decent in a .41" rivet hole but you don't want to have any slop in the hole because it will shear off easily on impact.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 07-13-2013, 02:18 AM   #6
67ctener
67ctener's Avatar
Lmc makes a complete kit to replace all rivets with grade 8.
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
67ctener is offline   Reply With Quote
Old 07-13-2013, 09:40 AM   #7
midniteblues
midniteblues's Avatar
you can get the rivits out and run a 7/16 tap through the holes without drilling them helps keep everything snug.
i will say the tap will not take a full bite into the hole but it will leave a good enough thread too be able too snug the metal together without useing a nut
(just sayin)of course your gonna wanna put nuts on.
you can attack the rivit with a combo of a cut off wheel/grinding disc,drill,or a cold chisel &bfh.
what i found too work good was to cut a x into the head of the rivit and knock it off with the chisel.of course you could drill a hole an knock'em off also
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
