Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 07-14-2013, 02:06 AM   #1
73chevy95
73chevy95's Avatar
73 Chevy C-20 Flatbed Build
Hey,
new on here, figured I would show what i just picked up.
any info or suggestions are appreciated
1973 Chevy C-20 Custom Deluxe flatbed
350(I believe its mostly stock) Edelbrock 600 Cfm carb with Edelbrock intake
Sm465 (not positive on that) bottom left is reverse,granny low and 3 speed
np202 ( out of an old IH)
dana 14 ( i don't know if it's full float or semi float)
some weird front axle, doesn't look like a 44 or 10 bolt, some combination of dana 30 or somethin, front is 6 lug and rear is 8
315/75r16 toyo open country MT
interior is screwed up!!! toyota bench seat, steering colum was an auto... so to start it I had to F**** with the old shifter, so i fixed that and wired in a push button start
Plans so far:
swap front axle out for a 3/4 dana 44 with disc brakes
swap rear leaf hangers under frame to eliminate blocks and add a little lift to run 37's
hedman headers backed by purple hornies!!
2000+ chevy bench seat, I want the flip down center console
Rebuild the carb for a smoother idle
Open to any suggestions and information
thanks guys!!!
-JJ
73chevy95 is offline   Reply With Quote
Old 07-22-2013, 02:20 PM   #2
meatwagon83
meatwagon83's Avatar
Re: 73 Chevy C-20 Flatbed Build
it has potential thats for sure! looks like the front axle needs to go forward a few inches, and you have the same brush guard as me! (cucv)
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 07-23-2013, 10:12 AM   #3
manimal
manimal's Avatar
A few more pics would help.
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
4x4, custom, deluxe, flatbed
