Old 07-15-2013, 08:40 AM   #1
marlo73
little Larry's valve's
Was wondering if anyone had any knowledge on these manual valves seems kinda pricey but they are sosposed to be faster than the airlift paddle valves.
http://www.littlelarrys.net
marlo73 is offline   Reply With Quote
Old 07-19-2013, 06:14 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: little Larry's valve's
They sure do look cool.
Wish they didn't have the name engraved in the front of them.
Keith
Convert to disc brakes.
Old 07-19-2013, 06:19 AM   #3
marlo73
Lol I was thinking the same thing but I heard you can get it blank I emailed to see if I could have something custom put on it.
Old 07-28-2013, 11:08 PM   #4
KYburBN
yeah just put a set of them on a customers 66 c10. worked great and super fast compared to the other manual valves. used 3/8 line whick is a benefit and the valves can work as fast or slow as you want them to.
only minor complaint is they are not as responsive as an electric valve which is expected. hope that helps.
very plzed
KYburBN is offline   Reply With Quote
Old 07-29-2013, 01:17 AM   #5
marlo73
Smile Re: little Larry's valve's
Cool thanks sounds good. So you ran 3/8 line from bags to valves and 3/8 from valves to tank as well. Also did you make a video.
Old 07-29-2013, 06:42 PM   #6
KYburBN
yup. 3/8 line all around. you could run 1/2 if you want but the 3/8 is more than sufficient. i can make a video give me a day or so and i will post it..
one other thing good about these valves is all the guage ports are made into the block so you dont have alot of t's or crazy fittings to install to read bag and tank pressure.
makes for very clean install and super easy to diagnose an issue if one occurs.
5 lines and your system is up and running.
if you dont use guages just remember to plug the 1/8 ports for the guages. lol
Old 07-30-2013, 05:01 AM   #7
marlo73
Cool thanks for all the help I'm going to purchase them I noticed you said five lines is all you need but what did you do as far as exhaust isn't there a 6th port for exhaust and if so did you just put a fitting on it and run a line outside the cab through the fire wall.
Old 07-30-2013, 12:13 PM   #8
KYburBN
yaeh there is a port for the exhaust. you can put a fitting in and run it out of the cab. i used an air muffler and installed it in the exhaust port. and left it inside the cab. its not very load and i didnt have to put another hole in the cab. your system will work even if you leave the exhaust port open.
Old 08-06-2013, 11:18 PM   #9
marlo73
You ever get a chance to take that video
Old 08-09-2013, 12:26 AM   #10
fastcam1
Young gun
fastcam1's Avatar
I really want accuair but these little larry valves do look pretty cool
67 SWB Custom "JANE"
http://67-72chevytrucks.com/vboard/s...d.php?t=554024
Northwest C10's
http://www.facebook.com/#!/groups/Norhtwestc10s/
Cameron sparks
fastcam1 is offline   Reply With Quote
Old 08-19-2013, 07:57 AM   #11
cochino12
It followed me home?
cochino12's Avatar
ttt
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
