Old 07-28-2013, 10:51 PM   #1
DENTON
73-87 trucks- what size lift for 37/38s? 6"? 8"? 10" or 12"?
In your opinion, if someone wanted to run 36-38" tires or thereabouts, what size lift do you think looks best on the 73-87 trucks?
DENTON is offline   Reply With Quote
Old 07-29-2013, 06:55 PM   #2
b454rat
Re: 73-87 trucks- what size lift for 37/38s? 6"? 8"? 10" or 12"?
Trimming? Flares? I have 38.5 boggers on my truck with 4' lift. It still rubs, not bad, but putting a 6" in it. Want a little more frame ground clearance, and not a huge fan of stuffed trucks....
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 07-29-2013, 07:00 PM   #3
DENTON
No trimming or rubbing wanted.
Old 07-30-2013, 02:30 AM   #4
dieseldawg142
dieseldawg142's Avatar
8" on a 1 ton, 10" on a half or three quarter.
good clearence, doesn't have that tire in the fender look
running 38.5's with 8" on a 1 ton
dieseldawg142 is offline   Reply With Quote
Old 07-30-2013, 03:23 PM   #5
Rubble
I ran 37s on the 82 K25 for a bit this spring/summer on 6" lift.The fenders have been trimmed a bit & no rubbing.16.5x8.75 rims.Went back to 35s though,too much tire for my poor 6.2!
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 08-13-2013, 02:54 PM   #6
dieseltech
86 K10 stock axles 6" rough country lift 37x14.5 tires on 15x10 rims no rubbing
1986 Chevy Wrangler 4x4
305/700r4
6" lift
37x14.50x15
dieseltech is offline   Reply With Quote
Old 08-14-2013, 08:00 PM   #7
Mr. 250r
Mr. 250r's Avatar
Its been awhile but if my memory serves correcet i had no issues running 36in militarys on my suburban with a 4in lift then went to 38.5s and just put a 3in body lift on and it will only rub if i were to say.... ramp the front of the truck, couldn't tell you back spacing on the 36s the 38s i could though if i went and looked lol
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 08-14-2013, 09:29 PM   #8
kellydown
I would think if you want no rubbing and don't trim the fenders, I would say a 10" in the front for sure...but then again a lot matters on tire width.
kellydown is offline   Reply With Quote
Old 08-15-2013, 02:22 PM   #9
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
I think you could go with an 8" and be ok unless its going to see a bunch of flexing would probably want a 9" or 10" depending on if u body lift or not. I got 39.5s with 9" lift and no rubbing. Doesn't get to much flexing usually just mud and back road cruising is all. Good luck on the truck
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 09-08-2013, 01:21 PM   #10
Your41Plague12
Your41Plague12's Avatar
My truck had a 6 inch suspension lift at first, and with my bushwhacker cut out flares it cleared 38x15.50 Baja claw radials no problem. I added a 3 inch body lift later on and I like the stance much better. If I were you I would go with an 8 inch lift and a narrower 38. No more than 13.50 wide or so. You may clear the 15.50's but I wouldn't risk it.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 09-10-2013, 12:05 PM   #11
LT.
The wheel offset and back space are going to make or break what size tire you can make fit. Lets say you were on a 15x14 wheel with a 2.5" back space the 36" tires would rub on a 6" lift.
I used to have a 82 chevy with an 11" lift, cut out bushwacker fender flares, and then brand new 39.5" tires rubbed on my 16.5x14 bart chrome wheels. I ended up swapping the 8" front skyjacker springs for some 10" superlift hd springs. Even with the bushwacker cut out fender flares the tires could still rub.
On a personal note, i usually prefer a lower lift size to make the tires fit. A 4" lift for 35" tires, a 6" lift for up to 37" tires and so on. An 8" lift for the 38" tires should work well. Again, depending on your tire width and wheel specifications.
LT.
LT. is offline   Reply With Quote
