Old 07-02-2003, 11:06 PM   #1
72MARIO
72MARIO's Avatar
Anyone Using Lowered Sway Bar Brackets ?
I was wondering if they fit good or what you opnion on them is.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 07-02-2003, 11:23 PM   #2
brad2
Hey Mario I put them on my Jimmy. The were a simple bolt on. There wasn't a swaybar on there before so I can't compare but it is much better than what is on my 74. I can get you a pic if you want.
74 swb
71 2wd Jimmy
82 2wd Blazer
brad2 is offline   Reply With Quote
Old 07-02-2003, 11:40 PM   #3
70 CST 4X4
Have A Nice Day!
70 CST 4X4's Avatar
Onelow69 put some on his truck and liked them. Think he got his from ECE. Don't think he had any problems with installing them.
1970 CST K10 350/350/205
Short Bed - Fleetside
Tach-Tilt-A/C-Tow Hooks
Front & Rear Disc Brakes
Front & Rear Posi 3.73 Gears
30 Gallon Stainless Fuel Tank
SOLD 01/18 !!!!!
2007 2500 HD Classic Crew Cab LT2 4X4 Duramax LBZ
70 CST 4X4 is offline   Reply With Quote
Old 07-03-2003, 06:19 AM   #4
72MARIO
72MARIO's Avatar
Cool I just wanted to make sure that they fit good with no problems before I buy them.
Thanks.
Brad,
How is the jimmy coming along ?
2005 TAHOE DD
Old 07-03-2003, 07:05 AM   #5
DR67
DR67's Avatar
Got mine from ECE, they were easy to install, and fit great.
DR67
Dave
Knoxville,Tn.
DR67 is offline   Reply With Quote
Old 07-03-2003, 08:46 AM   #6
tom hand
CCRider
tom hand's Avatar
I had a lowered 71 and instead of the lowered brackets I mounted the bushings directly to the frame....worked great. You might want to check that out before you pay for the brackets
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 07-03-2003, 05:22 PM   #7
Brad
Out of the carpool lane.
Brad's Avatar
That's how I installed mine also. Don't need brackets.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 07-03-2003, 07:01 PM   #8
Smooth68
Smooth68's Avatar
I'd like to see the pic Brad2 - I didn't know they made "lower" swaybar mounts -
Smooth68's Web Site
WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got??
'68 Short Step - Shaved Body, Soon Bagged - SOLD
Driver-2004 GMC Z-71 Ext-cab
Smooth68 is offline   Reply With Quote
Old 07-03-2003, 07:48 PM   #9
brad2
Is that sarcasm or are you serious. I know they are raised not lowered.:p
74 swb
71 2wd Jimmy
82 2wd Blazer
Old 07-03-2003, 07:49 PM   #10
SCOTI
SCOTI's Avatar
I bolted mine directly to the frame as well & used urethane bushings w/o any probs for 3yrs now & just went & bought all the grade 8 hardware to do my 74 the same way (but w/the bigger 1 1/4" HD bar).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-03-2003, 07:53 PM   #11
brad2
Mario the Jimmy is moveing along but has SO much more to go. Just got the floor in the back welded back in. It had to be raised for the new frame. Plus a new trans hump and tunnel for the driveshaft. Right now it's getting some new inner fenders. Looks like it will be sporting a taillight filler similar to yours also.
74 swb
71 2wd Jimmy
82 2wd Blazer
Old 07-03-2003, 07:54 PM   #12
brad2
SCOTI my 74 was a big block truck. Would it have the HD swaybar?
74 swb
71 2wd Jimmy
82 2wd Blazer
Old 07-03-2003, 10:09 PM   #13
SCOTI
SCOTI's Avatar
I'm not sure how bar size was determined from the factory. I got my small bar (1 1/16") from the donor truck used for my 68's disc brake swap which was a 1/2 ton lwb 75 model truck.
The HD bar ( 1 1/4") I'm going to use on the 74 came from a 1 ton flatbed dually in a wrecking yard. Both utilize EnergySuspension greaseable urethane bushings from Summit.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-03-2003, 11:24 PM   #14
Smooth68
Smooth68's Avatar
Sorry if that sounded wrong - Serious here...I would really like to see them.
Smooth68's Web Site
