Dash lights, dimmer switch
All lights were working fine, now only the outside lights, and flashers work. no dash lights or dimmer
is this the headlight switch that is bad, or something else. thanks guys
Jock, Powder blasting shop, Alabama |
P!$$ on Ford
Mine are out right now too and I couldn't find a fuse for it but maybe i'm just blind.
But my friend got pulled over at night for speeding and the officer asked "Do you know how fast you were going?" and he said "Nope, my dashlights are out." He got out of the ticket with the officer just telling him to fix them. So it might be a good thing ![]() But I still want mine fixed Michael
[FONT="Impact"][COLOR="Navy"] ![]() ![]() Lowered 1972 C-20 Longbed with 350 and TH350 ![]() 1995 Tahoe LS - Custom intake, k&n, TBI spacer, sweet tail lights, clear front lights... 2009 Nissan Versa I am 26, married, and we had our first baby in July of 2009 |
Most of these problems can be coming from bad ground connections. Check these first.
Good Luck. Cya, Edmond ![]()
1971 Chevy C/20 Longhorn, 350/TH400, Edelbrock Performer, IMPCO 425 LPG Carb 1974 Chevy Camaro Z28 (Original) ------------------------- Capelle a/d IJssel, The Netherlands |
1969 Custom 30 wrecker
I think there is a seperate fuse for them. (if memory serves) Take another look at the fuse panel. If you have an owners manual, that will probably show it better.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
Lights
Always wiggle the switch--rotate the knob back and forth a bit as the old contacts get dirty. You could spray some electrical contact cleaner into the switch from under the dash as you rotate the knob. Bet it works~~~~~~
#6 | |
1971 LWB Chevy C-10 350/350 3:42 eaton ![]() |
The tail lights share the same fuse as the dash lights.You might make sure they are still working.
