Old 08-02-2013, 10:12 AM   #1
cmose
cmose's Avatar
3 speed floor conversion
I just bought a 49 GMC, column shifter is worn out and hanging up. Any body changed over to a floor shifter? Any recommendations or suggestions would be appreciated. I know Hurst makes a kit, don't know if anybody else.
cmose is offline   Reply With Quote
Old 08-02-2013, 10:47 AM   #2
dubie
dubie's Avatar
Re: 3 speed floor conversion
I used a Hurst 3 speed floor shift conversion on my last truck. It's a very easy install and only takes about an hour once you've removed all your old linkages. I was sick of the 3 in the tree hanging up on me so we cut the hole in the floor and did the swap. I ran that truck for 7 more years without any issues before selling it
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 08-02-2013, 11:03 AM   #3
cmose
cmose's Avatar
Do you happen to have the part number? Did it come with everything you needed?
Old 08-02-2013, 11:55 AM   #4
Dan in Pasadena
Dan in Pasadena's Avatar
Just a contrary opinion:
Why not just fix the original linkage? All the parts are available through a variety of aftermarket sources and "threee-on-the-tree" is waay cooler than a floor shifter.
It's one of the things that says you're driving a classic truck; like the "wind wing" vent windows, the floor starter button, the cowl vent, the opposing windhsield wipers, etc.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 08-02-2013, 12:44 PM   #5
cmose
cmose's Avatar
Any links or part #'s for rebuilding the original shifter.
Old 08-04-2013, 07:26 PM   #6
dubie
dubie's Avatar
It was about 10 years ago so I don't have any part numbers but the kit came with everything I needed to do the swap
Old 08-05-2013, 09:51 AM   #7
Russell Ashley
Russell Ashley's Avatar
I too vote for keeping the original linkage. LMC truck has what you need to tighten it up. I got mine from BowTie Bits but lots of other vendors have it too.
I got my bushings that go in the shift rods at my local Ace hardware store.
Russell Ashley is offline   Reply With Quote
Old 08-05-2013, 10:50 AM   #8
Dan in Pasadena
Try chevsofthe40s.com
Old 08-05-2013, 11:15 AM   #9
dubie
dubie's Avatar
I agree that a 3 in the tree is a hell of a lot cooler than a floor shift. Most younger people wouldn't even have a clue how to drive one. Replacing the bushings and servicing the linkages is easy and effective to allow for smooth worry free shifting.
Old 08-05-2013, 04:04 PM   #10
_Ogre
_Ogre's Avatar
it's been a while, but a couple bucks for new plastic bushings is all it takes to rebuild your linkage
like dubie says; think of it as your anti theft deterrent
shop air compressor timer
