08-05-2013, 09:09 AM | #1 |
factory grease pencil marks?
I noticed these marks on my truck (70 C-10). I couldn't figure out why someone would have put them on the firewall, especially "blu" (I mean they obviously put it on there AFTER it was painted, right?) but then yesterday I noticed the same number on the inside of the RS fender when I pulled the inner and started thinking.
Are these factory assembly marks? Seems incredible they'd still be this intact after all these years if they are. If they are factory marks, then I've been spelling her name wrong all along- its "Blu", not "Blue." |
08-05-2013, 09:21 AM | #2 |
Re: factory grease pencil marks?
Yup there factory
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
08-05-2013, 09:22 AM | #3 |
Yes these are factory my Gmc has them also.
1970 GMC 1500 stepside 1972 GMC Jimmy Custom 2004 Chevy Colorado 1989 Swb Silverado 1972 Aj's Stormer |
08-05-2013, 09:26 AM | #4 |
That's pretty cool and amazing to me that they lasted this long. Guess I better be careful when I clean under the hood (and apparently nobody else ever cleaned under there!)
Thanks guys.... |
08-05-2013, 10:10 AM | #5 |
Hey John, As you continue to disassemble your truck, if you find anymore grease pencil markings could you post the pics up in this thread? Keep a eye out for that 902 number. That's probably the last 3 digits of the "job number" of your truck. The BLU is the first time I've seen a color name instead of the code, but I'm sure it's factory. It could be referring to the paint or interior color.
CHEVY/GMC VIN DECODERS |
08-05-2013, 10:12 AM | #6 | |
08-05-2013, 11:24 AM | #7 |
Proprietor of Dale's Corner
I don't think the BLU is a color but an inspectors initials my blue truck had ASH or ASK it was real sloppy couldn't tell which it said..
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
08-05-2013, 12:59 PM | #8 |
My 67 still has them. Didn't see any around the fenders when I had them off, but I wasn't looking either. I would like to try and figure out a way to preserve this, even though the original 327 is long gone.
Justin '67 C20 CST Custom Camper '04.5 LLY Duramax CCSB...sold |
08-05-2013, 01:02 PM | #9 | |
You might see it on the hood, rad support, fenders, grille, rear axle, inside the wheels: on anything that was built up remotely and then conveyed to the final line in sequence. My truck was number "87" (my truck was built on a Monday, btw ). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
08-05-2013, 01:03 PM | #10 |
I confirmed yesterday that I still have the original engine and transmission (matched the serial numbers to the protect-o-plate). I don't have a particularly collectible truck (long bed with no cool options) but its still neat.
08-05-2013, 01:22 PM | #11 | |
This is kinda like ancestry.com for gearheads, eh? |
08-05-2013, 01:24 PM | #12 |
I totally agree! Very cool indeed! that is the one thing about my truck, it has factory buckets, and a few other options, but the glove box doesn't look like there was ever a SPID, no residue at all. no protect-o-plate, or build sheet. Just the grease pencil marks on my firewall.
08-05-2013, 10:17 PM | #13 | |
My truck was built on Monday Sept 29 of 1986 (in Flint) and the VIN was already up in the 317000 range (60 jobs per hour, two shifts); similarly my Chevelle was built in September of 1973 in Oshawa and the VIN is also already up in the 300000 range. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 08-05-2013 at 10:32 PM. |
08-05-2013, 11:14 PM | #14 |
I had a 72 Cheyenne Super once that had "Red Orange" on the SPID and "Hugger Orange" in grease pencil on the cowl.
The Super I have now has "4T" on each side of the cowl. I have always assumed it stood for 4 tone to designate the red white red white paint scheme. Even though it's not four tones. The engine, trans, and rear codes are also on the cowl, which is common. |
08-06-2013, 07:36 AM | #15 | |
08-06-2013, 08:01 AM | #16 | |
The build sequence number absolutely increases one-for-one for every truck built. So at the beginning of the year you start with truck "01" and start counting, all the way to 700,000 or every how many trucks were built in that plant. The VIN sequence portion does not increment one for one....nor are trucks necessarily built in VIN order. In my day Chevy's started with 100001 and GMCs with 500001 (and then Cadillacs with 600001); so, while within a nameplate the VINs increment up one by one but because the various nameplates are jumbled in during the day's production run the VINs do not increment up exactly one for one overall. Let's say your daily build looked like this (I'm making this up for illustration purposes): PVI = "Primary Vehicle Identifier" - and is the way the cab/box are identified in body shop, before the GA (General Assembly/Final Line) sequence number and VIN are even created. There are two opportunities for the build order to be shuffled: coming out of body shop into paint, and coming out of paint into trim/GA. GA sequence number is the order in which the trucks go down the final line. Once they hit trim/final the build order is locked in. In the example shown here the operator would write the "901", "902" etc (or even just "01", "02") on the front of dash, rather than the full "299901". Does that help? K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 01-08-2016 at 11:49 AM. |
08-06-2013, 08:33 AM | #17 |
So - the purpose of the above example was to show what the "902" means.
But - there are some other nuances buried in there, that I put there on purpose, that I would like to discuss briefly: a) Vehicle order numbers: those are real live actual dealer order numbers. That's how they look in terms of alphanumerics, and in order (all jumbled up). I've never seen any kind of rhyme or reason (or intelligence) in how the order numbers are constructed. b) PVI - is the primary tracking number prior to GA and is established after the dealer order number is received at the plant and released for production. The vehicle cabs and boxes were built in PVI order through the body shop but shuffled going into paint, due to repair, rework or part availability. c) GA sequence - the cab and box get shuffled again, coming out of paint before dropping into trim/final. This is again due to any repair or rework or part availability, but additionally to balance the workload for the people in trim and final. Said differently, you can't have too many air conditioning, manual trans, cab roof marker lights, dually boxes, etc (high work content) vehicles in a row. Gotta spread 'em out a bit. d) Notice how the VINs increment up one by one within a brand. That is not always the case but I have left it that way for the purposes of this example. e) Notice how there is a GMC every 9th or 11th job, and a Cadillac every 20th job. That was intentional. The VIN sequence reflects the production volume of that brand built, too, ie: at this point 200,000 Chevy's have been built (317388 minus 100001), but only 20,000 GMCs (521102 minus 500001) and only 10,000 Cadillacs (610101 minus 600001). f) Those vehicle owners are for pre-production internal users. For regular production that would be the actual ultimate customer (Keith Seymore, or Bruceman, or DavisChevy, etc) Just a reminder: on my truck the GA build sequence number was "87" but my VIN ends in "317388". K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 08-06-2013 at 08:52 AM. |
08-06-2013, 08:53 AM | #18 |
Any chance the 902 number refers to the PVI number or vehicle order number, instead of the GA number? From your last post it sounds like the GA number isn't known until the assembly process. In the research I have done, that number shows up before the assembly process. I have documented that number showing up during the stamping of the pieces used to make the truck. Here is a example.
I took this pic and the stamped number is 214 I have documented several trucks with the stamped number matching the grease pencil number. Any light you can shed on this would be greatly appreciated. I have used the info you provide in your posts a lot to help me do this research. you are a most valued resource. Thank you for all the knowledge you share with this board. We need more assy line guys on here. P.S. I love the story of how you followed your truck down the line. To cool
CHEVY/GMC VIN DECODERS Last edited by bruceman1968; 08-06-2013 at 09:10 AM. |
08-06-2013, 10:05 AM | #19 | |
Yes - good examples - in the examples you have posted it looks like the trucks were built "straight through", meaning the PVI (not the dealer order number) and the final line GA sequence number were the same. No shuffling occured after body shop or after paint. The stamped portion was done in body shop after the cab was welded up and then the grease pencil after paint. Were those Fremont trucks, perhaps? Fremont built straight through (no shuffling). Re: Following my truck down the line: I wish now I had kept some of the paperwork (the build manifest, build sheet, inspection paperwork, etc) from that day but I didn't even think of it until recently. I actually followed two of my own personal trucks down the line for fun - but now I follow preproduction builds down the line for a living. Probably not; then we would just argue with each other... K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 01-08-2016 at 11:48 AM. |
08-06-2013, 02:36 PM | #20 | |
All the trucks I have documented so far (with a grease number and a stamped number) have been from Fremont. Even have a GMC. Thanks again Keith, your responses really do shed a lot of light. I appreciate the help.
CHEVY/GMC VIN DECODERS Last edited by bruceman1968; 08-06-2013 at 02:44 PM. |
08-06-2013, 03:55 PM | #21 |
Keith- thanks for all the info- that was a great tutorial!
01-03-2014, 12:02 PM | #22 | |
KEEP ON TRUCKIN'
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" |
01-03-2014, 12:13 PM | #23 |
Florida Edition
Great thread!
#214 is in my shop and destined for greatness
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
01-03-2014, 12:50 PM | #24 |
Jim, Do you have a pic of the mustard writing. I would like to have it for my collection. Also any pics of the 215 written anywhere. IIRC your truck has been painted, so if you don't have the pics, no problem. Just thought I'd ask.
01-03-2014, 01:22 PM | #25 |
