Old 07-03-2003, 11:45 AM   #1
69sixpackbee
Unhappy Question To You 60/40 Power Seat People...
The '94-'98 power 60/40 drivers seat has a different mounting bracket than the other ones. Instead of a bent leg front to back and spaced about 15" my power seat has a more solid semi-rigid bracket with the bolt pattern at about 10". When you installed yours did you go ahead and set it to the floor with the front bolts in the existing raised mounting area and bolt the rear one down or did you use a spacer to match the same height as the raised section @ the front for the rear mounting?
Thanx!
69sixpackbee is offline   Reply With Quote
Old 07-03-2003, 05:37 PM   #2
john
member #16
john's Avatar
I set mine behind the raised area where it sat flat on the floor, and drilled all new holes. your seat will sit lower that way.
john is offline   Reply With Quote
Old 07-03-2003, 05:43 PM   #3
69sixpackbee
Thanx for the reply, John. Are you saying that this seat sits a little higher than the original?
Old 07-03-2003, 06:03 PM   #4
john
member #16
john's Avatar
I think it will sit higher than origional mounted on raised area. The one I did was the same as origional seat mounted flat. I think mine was 13" from floor to top of seat cushion,as was origional seat. If you have long legs it makes a difference.
Old 07-03-2003, 06:05 PM   #5
69sixpackbee
I have long legs so yes it sounds good. Besides, if I want to raise it up I just push the button, right?
Thanx!
Old 07-03-2003, 06:08 PM   #6
john
member #16
john's Avatar
heres a pic
Old 07-03-2003, 06:19 PM   #7
jays68yak
jays68yak's Avatar
dunno i used bucket seats
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds.
1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s
1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig
"I like long walks, especially when they are taken by people who annoy me. "
jays68yak is offline   Reply With Quote
