Old 08-06-2013, 09:41 AM   #1
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
Hotchkis TVS
I am currently thinking I am going to do the full Hotchkis TVS kit for my truck. Wondering if anyone has used aftermarket trailing arms with this kit?
Also looking for the best price on this kit. Summit and JEGS seem to be the best I can find... Anything else?
chevyguy_72 is offline   Reply With Quote
Old 08-08-2013, 11:40 AM   #2
chevyguy_72
Vintage Evil
Re: Hotchkis TVS
Anyone?
Old 08-08-2013, 04:57 PM   #3
68Stepbed
68Stepbed's Avatar
Re: Hotchkis TVS
I think Rob Philips used ECE arms on his 69 C10. Mike Holleman used reinforced stock arms. That's really the only two people I know that have the Hotchkis kit.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 08-09-2013, 01:57 PM   #4
Jon @ Hotchkis
Jon @ Hotchkis's Avatar
Re: Hotchkis TVS
Hi Chevyguy, our TVS kit should work just fine with aftermarket trailing arms that are direct replacements. One issue you may run into is the sway bar end link-mount on the trailing arm; on the stock arms you have to drill a hole and weld on a brace, so depending on the design of the aftermarket arms this may not be possible. Make sure that the arms you purchase do not have any additional drop built into them, otherwise you will run into axle to frame issues.
Let me know if you have any other questions.
Jon Rasmussen
Hotchkis Performance
877-466-7655 ext. 224
jrasmussen@hotchkis.net
Check out our Facebook page!
Jon @ Hotchkis is offline   Reply With Quote
Old 08-09-2013, 03:59 PM   #5
68ls1
68ls1's Avatar
Re: Hotchkis TVS
Hi Jon, rather than start a new thread I thought I'd join in on this one.
I too am considering the TVS Kit for my 72 Stepside, I was also planning on installing the Early Classic Extreme Drop Center Crossmember & Trailing arms
Name:  trailing arms black and white.gif
Do you see any issues with installation of sway bar end links & anti squat brackets?
I also plan to use the CPP Modular drop spindles, in installation PDF it advises use of 73-87 version, will I be able to use my original disc brake set up with this version or can I use 71-72 version with ball joints, Part # FA683
Big brake & wheel upgrade is next planned upgrade
thanks Roger
68ls1 is offline   Reply With Quote
Old 08-09-2013, 05:23 PM   #6
Jon @ Hotchkis
Re: Hotchkis TVS
Do you see any issues with installation of sway bar end links & anti squat brackets? I don't see any glaring issues why not. It looks like their drop member uses the same bolt pattern for the trailing arm mounts, and with their arms being boxed already all you would need to do is drill the hole for the sway bar end links.
This part is really up to you, as you can go either way. You are correct about the ball joint though, to run the 71-72 spindle you would need the FA683 ball joint and a 5/8 inner tierod to be used as an outer.
thanks Roger
Jon Rasmussen
Old 08-14-2013, 11:51 AM   #7
chevyguy_72
Vintage Evil
Re: Hotchkis TVS
Originally Posted by Jon @ Hotchkis View Post
Any possibility of a forum hookup on this kit Jon?
Old 08-14-2013, 05:32 PM   #8
Jon @ Hotchkis
Re: Hotchkis TVS
PM me and I'll see what we can swing.
Jon Rasmussen
Old 08-15-2013, 01:40 PM   #9
chevyguy_72
Vintage Evil
Re: Hotchkis TVS
PM sent
Old 08-20-2013, 08:03 PM   #10
GEARBOXGARAGE
Re: Hotchkis TVS
Attachment 1139180
Attachment 1139181
thanks Roger
I used those arms and cross member with the Hotchkis Blade Style sway bar and they worked great. One thing I did was drill out the bolt hole oversized and welded in a piece of DOM Tubing to help keep from over tightening the bolt and keep the tubing from crushing. I also flipped the trailing arm mounting brackets in the cross member to gain in anti squat, but the TVS will have that covered with the new brackets.
GEARBOXGARAGE is offline   Reply With Quote
Old 08-20-2013, 08:08 PM   #11
68ls1
68ls1's Avatar
Re: Hotchkis TVS
Thanks for feedback, much appreciated
