Old 08-07-2013, 01:41 PM   #1
t300
Why are most air ride gauges 200psi?
Seems as though a lot of posts here indicate guys are running anywhere from 60-90psi up front, and a lot less in the back. Most gauges I see advertised for sale (including board vendor kits) are 200psi units. It would seem to me that a 100psi gauge would give a lot more resolution on what PSI you are actually running. At a glance, I can barely tell what the rear of my truck is at within 10psi. Its a manual setup and I like to target certain PSI so my ride height (and therefore alignment) is consistent.
Am I missing something?
May as well throw out a pic of my '70, running on SS7's and manual valve setup from Travis @ AZPro. Love the truck!
Matt
t300 is offline   Reply With Quote
Old 08-07-2013, 11:04 PM   #2
davidfre21
Re: Why are most air ride gauges 200psi?
Just depends on the setup. Smaller air bags on different trucks need more pressure to lift. And most compressors run 150psi or more so why not make everything consistent
davidfre21 is offline   Reply With Quote
Old 08-08-2013, 01:54 AM   #3
Pro Performance
Pro Performance's Avatar
The air gauges are sometimes used for different purposes, such as tank pressure, etc. I do agree with what you are saying though, and this is why we choose the smaller reading for the gauges in our Pro1 and Pro2 kits. That being 160 PSI. The manual system does use the 200 PSI, which is just how that system is configured, but something we might want to change in the future. Just the way it has been for a long time.
Thanks for posting up a pictures, looks great. I like the stance of the truck with your wheel / tire combination.
- Travis
Pro Performance is offline   Reply With Quote
Old 08-08-2013, 07:06 AM   #4
502ms
502ms's Avatar
Great question. I will tell you that I have a dual 160 psi gauge, and it helps me put the truck at the right height quickly. My new ride height is 80lbs front, 60lbs rear. If the road is horrible, I will bump it up to 90lbs to be safe. I max at out at full height around 125lbs front and 140lbs rear (stilts)
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 08-09-2013, 11:45 AM   #5
t300
thanks for the replies guys. I'll keep my eyes out for some 160psi dual gauges. Or maybe a dual 160 for the front and a dual 100 for the back, if there is such.
Matt
Old 08-09-2013, 12:24 PM   #6
Madmartigan
I run dual needle gauges out of a Kenworth. They are only 150psi and can be found cheap on eBay if you are patient.
Autometer air pressure gauges are single needle but are 150psi. However, boost gauges are available in 0-35psi, 0-60psi or 0-100psi. Air is air, it will just say boost along the bottom.
Dakota Digital also sells a single digital gauge which will show all 4 bags.
Madmartigan is offline   Reply With Quote
Old 08-12-2013, 02:02 AM   #7
wraprail
wraprail's Avatar
Dakota Digital and you know exactly what your pressures are.
wraprail is offline   Reply With Quote
Old 08-15-2013, 09:30 AM   #8
STPrider
STPrider's Avatar
Forgive me if this is a dumb question, but wouldn't there be a considerable pressure spike from hitting a bump, railroad tracks, speed bumps, etc? I've always wondered this, and does this show up on pressure gauges?
'71 GMC pickup; "Ashley,"
STPrider is offline   Reply With Quote
Old 08-15-2013, 11:28 AM   #9
davidfre21
It does show the jumps but it's something you learn and live with
Old 08-18-2013, 09:18 PM   #10
Mikec10
Mikec10's Avatar
Yeah you see it but, doesn't really bother me.
1980 C10 SWB Yukon 5.3/5 speed 3.73 gears.
Mikec10 is offline   Reply With Quote
