![]() Join Date: Aug 2011
5 on 5 Chevy wheels
I kinda thought that the 5 on 5 bolt pattern was a pretty common wheel and would be easy to find .......
Well it is not near as easy as I was hoping for. Have been looking on Craigslist in Las Vegas, Phoenix and around California and it's been impossible to scare up some good looking wheels. Question is..... What year vehicle and model should I be looking for so maybe it would be an easier search? I have a '76 front end and a '72 rear with the 5 on 5 bolt pattern.
http://s994.photobucket.com/albums/af62/ScottAz2/ |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: 5 on 5 Chevy wheels
Any 73-87 2wd is the same bolt pattern.
What are you looking for?
Was looking for some WELDS or CENTERLINES 10" wide in the rear and 8's in the front.....15 inch or maybe some smoothies....baby moons....nice clean look
http://s994.photobucket.com/albums/af62/ScottAz2/ Last edited by McCoyAZ; 08-11-2013 at 10:48 AM. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
71-98 half ton 2wd trucks used the 5 on 5 pattern, along with many vans, Suburbans, and even some full size cars. I suspect its the second most common bolt pattern ever made, after the car 4 3/4 one.
Posted via Mobile Device |
#5 | |
I am finding tons of the 4.5 or the 5.5 on 5 but darn few 5 on 5. There will be some pop up one day.
meowMEOWmeowMEOW
I find plenty of stock wheels but I think you'r pushing your luck hoping for a used set of Weld's in the exact offset, spacing and pattern you need.
If you want cheap custom wheels, Diamond Racing makes dirt track wheels in a bunch of styles, many of which look at home on street cars too. Pretty much any configuration, and they are like less than $100 a wheel.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#7 | |
Yeah I know, but I gotta have something to look for :-)
Chevrolet Impala, Caprice from 60s thru 1996 are 5x5". Mid to full size Ford, Lincoln cars (t-bird, mark v, Ltd, country squire) from early 70 thru early 80s are also 5x5"
![]() Join Date: Aug 2012
Some of the mid 80's Impala's had both 4.75" & 5" bolt patterns depending on brake sizes. I'm not sure how many years this was like this but just be aware that not all are the 5x5 pattern.
I'm just glad to be here!
the early-mid 90's Impala SS had 5 on 5 pattern wheels. I have seen those stock wheels on a truck and they look OK.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#11 | |
Also I forgot all Astro vans are 5x5 iirc. I was in the wheel & tire business but its been 25 years. Posted via Mobile Device All GM big car from 1991-96 are 5x5 ( Impala, Caprice, Buick Roadmaster, Cadillac Fleetwood)
