Old 08-13-2013, 12:09 PM   #1
ibanezer
ibanezer's Avatar
Starting on a Dropmember frame soon, need advice
Hi all,
I have a '68 LWB C20 and plan on the following:
-Porterbuilt Dropmember - front and rear(already have both kits) - weld in notches for the rear
-Drop spindles of some sort(do not have yet)
-73-87 upper and lower arms and brake components
-Plan to run 22" smoothie wheels, "Delmo specials"/Mobsteel, etc.
I should be getting my frame set up in the next month or so. My question right now is in regards to tire size. I'm not sure what size tire I should run once I do eventually buy the 22" wheels. I'm looking at throwing some 15" truck rally's on it, just for the purpose of setting the 4-link up and to get it rolling.
To sum this up, when I do get 22's for the truck, what size tire should I run? Also, what size tire should I put on a 15" wheel for now to set my 4-link up right?
1968 C20 LWB. Soon to be Dropmember'd.
ibanezer is offline   Reply With Quote
Old 08-13-2013, 01:08 PM   #2
blazins10
blazins10's Avatar
Re: Starting on a Dropmember frame soon, need advice
mine was setup on a 265-35-22 , which is like 29 inches tall
///Relaxed Atmosphere
blazins10 is offline   Reply With Quote
Old 08-13-2013, 02:01 PM   #3
ibanezer
ibanezer's Avatar
How wide of a wheel did you have? Any pics of it?
Old 08-13-2013, 03:21 PM   #4
Pro Performance
Pro Performance's Avatar
It all depends on personal preference, but that size mentioned is a good suggestion. Also depends on width of 22's you plane to run. Here is a members truck with 22's, running 305/40/22 on a 22x10 & 265/35/22 on a 22x8.5. If you did 8.5's all around, or something similar, that 265/35/22 is a good size tire.
Pro Performance is offline   Reply With Quote
Old 08-13-2013, 03:22 PM   #5
craig7070
craig7070's Avatar
Love it
1972 C10 Custom Deluxe 2 Owner Project "Lumberjack" 83K Original miles
Work in progress....Got the truck for free all original
craig7070 is offline   Reply With Quote
Old 08-13-2013, 03:32 PM   #6
SCOTI
SCOTI's Avatar
Pick the wheel & tire combo you want. That establishes your overall height. Then choose a 15" combination thats as close as possible. I'd do 285-40-22's on a 22x10 @ 31" tall. A 235-75-15 w/a 2" spacer under the rubber would be fairly close (28.8 + 2 = 30.8").
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-13-2013, 03:47 PM   #7
ibanezer
ibanezer's Avatar
That truck looks great, I've seen it all over the internet..
I do plan on 22x10's for the rear. The back tires on the truck above do look pretty meaty, so I think the 285-40-22 would be a good choice. The 2" spacer idea is a good one also, I'll keep that in mind. Thanks for the input guys.
Old 08-13-2013, 03:55 PM   #8
Pro Performance
Scoti, good point..... it is important to use the same diameter tire when mocking up, as you plan to use on the final tire.
Old 08-13-2013, 09:12 PM   #9
broey
Square
broey's Avatar
does mod steel name a 22? I thought only 18s and 20s?
Squarebody Syndicate
broey is offline   Reply With Quote
Old 08-13-2013, 10:40 PM   #10
82swb
82swb's Avatar
For now only 18s and 20s. 22s are in the works. I spoke to someone in their sales department and they said by the beginning of 2014 they hope to have 22s ready for purchase.
82swb is offline   Reply With Quote
Old 08-14-2013, 01:34 AM   #11
64shortc10
64shortc10's Avatar
Delmo sells a 22 inch steel wheel now!
Tony from Norcal
64shortc10 is offline   Reply With Quote
Old 08-14-2013, 01:46 AM   #12
andrewmp6
If you want the same kinda style rim but a 18 or 20 http://www.rallyamerica.com/Billet_Solid.html
andrewmp6 is offline   Reply With Quote
Old 08-14-2013, 06:19 AM   #13
lolife99
67-72 parts collector,…
lolife99's Avatar
Tony from Norcal
That looks ALOT like the 22" GM transport wheel.
The "triple lip" gives it away,...
Keith
Convert to disc brakes.
Old 08-14-2013, 06:25 AM   #14
64shortc10
64shortc10's Avatar
Those look nothing like the ones Delmo sells!
Sssssshhhhh!
Tony from Norcal
Old 08-14-2013, 06:59 AM   #15
Rochlow
Saw the new Delmo Specials on FB the other night. The thing I don't like about those wheels is that with a 6" backspacing they look akward in the rear and the triple step lip. (which has nothing to do with Del)
Rochlow is offline   Reply With Quote
Old 08-14-2013, 08:38 AM   #16
ibanezer
ibanezer's Avatar
I didn't know Delmo was actually selling those lol. Does he sell 5 lug versions? And I have also heard that Mobsteel is working on 22's, by the time I'm ready to buy wheels I may even have a few more options.
Did Delmo originally use Centerline smoothies and modify them to accept the old GM caps? I haven't had a chance to research how that was done yet
Old 08-14-2013, 08:42 AM   #17
Rochlow
The GM transit wheel in the picture above only comes in 6-lug.
In the past Del has used Centerline smoothies.
Old 08-15-2013, 04:08 PM   #18
Artikgrau325is
Woah! Does anyone know what wheels these are? That's exactly the look I'm going for.
Artikgrau325is is offline   Reply With Quote
Old 08-15-2013, 04:23 PM   #19
Pro Performance
Yep, those are Raceline Blast 5's that we got for him.
http://www.azproperformance.com/Race...s-Blast-5.html
Old 08-15-2013, 05:26 PM   #20
Artikgrau325is
You're a gentleman and a scholar. Thanks, I need to send you an email sometime, I know I meant to order some things from ya but there have been... Complications.
