Old 08-18-2013, 05:00 AM   #1
JointTech
JointTech's Avatar
wheels not returning to center well
I got new wheels and tires and have finally been able to put a few miles on the truck. Its tracks straight on the road but sharp turns it doesnt like to straighten itself back out.
Can an alignment guru look at my numbers and tell me what would be better. I got a little lost in the make it handle thread.
if you click on the image you can see the fullsize one. this forum doesnt let you have big pictures anymore so you cant read it.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 08-18-2013, 09:18 AM   #2
Square_78
Square_78's Avatar
Re: wheels not returning to center well
Isn't that the caster that helps to pull the wheels back straight.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 08-18-2013, 09:22 AM   #3
ulakovic22
I was actually looking at your initial settings. Your final numbers look good, in terms of caster one side is higher to adjust for the crown in roads and almost 3.5 should be good to return to center. Could be gearbox related. Manual or power?
Anthony
'67 Shortstep (555/T56)
'67 Parts Truck (TBA)
ulakovic22 is offline   Reply With Quote
Old 08-18-2013, 09:28 AM   #4
Square_78
Square_78's Avatar
Wheels should be towed in ever so slightly
#teamlongbed
Old 08-18-2013, 12:48 PM   #5
chevyrestoguy
chevyrestoguy's Avatar
I would have the shop get the caster angle even from side to side, and then test it out. That's too big of a difference from side to side, in my opinion. Low or unequal caster numbers will cause you to "chase" the steering as you drive it, always correcting and trying to bring it back to center. For the crown in the road, a change in camber on the passenger side may help, but that theory is often debated. I'm not a fan of that theory. The road would have to be extremely crowned to see any benefit from that adjustment, in my opinion.
I've had my best success with mirror-image values from side to side. It tracks straight, and the tires have even wear.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 08-18-2013, 12:50 PM   #6
jd7
jd7's Avatar
more caster.... and yes a little two in would help. Caster should be even if the drifting is a problem due to the crown correct it with a little camber
jd7 is offline   Reply With Quote
Old 08-18-2013, 03:12 PM   #7
JointTech
JointTech's Avatar
its power steering.
all the suspension and steering parts other than the rear leafs are new. gearbox to tierods.
when i go around a corner in my scion I can just let the steering wheel slide when powering out of the turn and the car naturally wants to straighten out. Truck doesnt do that.
so ill see if they can give me more caster and even it out. As well as more toe.
anybody got a similar sheet of numbers I can see?
72 C20 Long Bed
Old 08-18-2013, 05:45 PM   #8
Mikec10
Mikec10's Avatar
Originally Posted by JointTech View Post
its power steering.
Over adjusted steering box could cause it not to center well.
1980 C10 SWB Yukon 5.3/5 speed 3.73 gears.
Mikec10 is offline   Reply With Quote
Old 08-19-2013, 05:51 PM   #9
JointTech
JointTech's Avatar
talked to my alignment guy today. He's going on vacation so ill bring it by next week.
He said less castor helps in return to center. And toe doesnt help it track straight it just deals with the steering wheel being straight and the tierods being equal distance. Going to do some more research before taking it. He has a computer thingy so he can dial in whatever I tell him to. Just need to know what to tell him.
How do you overadjust a steering box? I have a reman I just put in. new pump, rag joint, brakes, springs, shocks, tierods, ball joints, pitman and idler arms, sway bar bushings, tires and wheels, wheel bearings, rotors, calipers, pads, shoes, rear drum hardware/springs. In fact the only things not new under the truck are
leaf springs, spindles, drums.
72 C20 Long Bed
Old 08-19-2013, 08:16 PM   #10
jd7
jd7's Avatar
Wish you were a tad closer, I would help you out. did you have this problem before the tires and wheels were installed ? Or is this after all the upgrades ?
Old 08-19-2013, 08:24 PM   #11
JointTech
JointTech's Avatar
it was basically undrivable before I did all the fixes. Tires and wheels was the last thing to make it road worthy.
So I dont really have anything to compare it to other than I dont remember it being like this on my old blazers growing up. Hell I dont think my split axle dump truck has a problm coming back to center out of a corner. lol
72 C20 Long Bed
Old 08-20-2013, 08:31 PM   #12
jd7
jd7's Avatar
I'm doing some work on my 69 Saturday if i get the time i will put it on the rack and post the numbers for you. Does the steering feel stiff to you ?
Old 08-20-2013, 08:34 PM   #13
JointTech
JointTech's Avatar
now that you mention it it does seem a tad stiff. I remember growing up all our pre 80s hooptys with power steering were 1 finger type trucks and cars. I replaced my PS pump because it was slipping and squealing but wonder if the new one isnt strong enough?
72 C20 Long Bed
Old 08-20-2013, 10:53 PM   #14
Fastest32
Fastest32's Avatar
That difference in caster seems huge to me.
BaBaBooey BaBaBooey
GO SPURS GO!!!
Fastest32 is offline   Reply With Quote
