Old 08-23-2013, 06:30 AM   #1
JimJones
What happens if you drive with you hubs locked all the time?
Can this cause damage? What about burnouts and fishtailing?
If I remember correctly the reason you have front hubs in the first place is because when you drive on hard pavement with the hubs locked the rotational differences between the front wheels and rear wheels could damage the transfer case so you are only supsto drive with the hubs locked on the dirt. Is this right or wrong?
Can you put a locker or limited slip or Detroit locker in the front axle? And if you did so would you still need to have hubs?
I was watching this vid
And noticed that this truck has center caps on the wheels that cover the hubs. That is what prompted this question.
JimJones is offline   Reply With Quote
Old 08-23-2013, 06:40 AM   #2
Bigdav160
Bigdav160's Avatar
Re: What happens if you drive with you hubs locked all the time?
Locking the hubs causes the internal parts of the front axle plus the front driveshaft and a couple parts in the transfer case to rotate all the time.
It doesn't hurt anything except gas mileage.
The front to rear forces you are talking about happen when the transfer case is engaged also.
My daily driver Dodge Ram does not have hubs but a front axle disconnect. My Wife's DD Ram is a year newer and it does not. The axle spins all the time.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 08-23-2013, 06:52 AM   #3
The purpose of lock-out hubs is to allow the front wheels to "free wheel",the same as a 2wd. They are an after thought that was not originally part of the design. The axle does not BECOME "live" until the transfer case is engaged from inside the cab. With hubs locked-in and transfer case in 2Hi,the wheels are turning the axle shafts and the driveshaft can also turn. With hubs locked-in and transfer case in 4Hi (or 4Lo),the wheels are turned by the axle. The point of lock-out hubs is to save wear & tear on the front drive parts,tires (some),and fuel economy (less drag).
You can run traction devices in front axles. You would only want a locker if the vehicle was strickly used on poor traction because the differentiation between wheels when turning,as you mentioned,is a concern. A posi/limited slop is what you need in front. GM offered a front posi,that few trucks were spec'd with
Old 08-23-2013, 10:54 AM   #4
Bigdav160
Bigdav160's Avatar
To add to special-K's comment.
I have an eaton e-locker in my front axle (dana 44)
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 08-23-2013, 04:44 PM   #5
dieseldawg142
dieseldawg142's Avatar
at 5-6 mpg's, i leave mine unlocked on the road, but soon as i go off-road, there locked. nothing worse than having to get out in the water or mud to lock them
dieseldawg142 is offline   Reply With Quote
Old 08-23-2013, 05:34 PM   #6
72chevyk10
I built it
72chevyk10's Avatar
its actually good to run the hubs locked with xfer case in 2wd every once in a while. helps keep everything loose and ready to use. in fact as soon as winter hits my hubs are locked all winter until there is no chance of snow. shift on the fly 4wd!
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
Originally Posted by prostreetC-10 View Post
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 08-24-2013, 10:28 PM   #7
JimJones
Thanks for clearing that up guys.
Anybody care to venture a guess as to what size tires and rims are on the truck above?
Old 08-25-2013, 01:17 PM   #8
72chevyk10
I built it
72chevyk10's Avatar
id say about 35"s with 17" wheels
Old 09-03-2013, 11:30 PM   #9
willett
Another Day, Another Dollar
willett's Avatar
You will scrub the crap out of your tires!
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
