Dash Cluster Light Out
Last night I installed my RetroSound Stereo and new Dash pad. I had to pull the dash cluster out (gently) to screw in the dash pad, what a PITA. Got everything screwed back in and fired the Blazer up only to realize that the dash cluster light is out. The red dot bright indicator still works, as well as the turn signals, but everything else is dark. I traced the dash cluster light wire back, doesn't seem to be any issues there. Where else should I look?
![]() Join Date: Oct 2008
Re: Dash Cluster Light Out
Could be your interior lights dimmer turned off.
Your light switch turn right to brighten and all the way for dome and interior light
Cluster King
![]() Join Date: Nov 2012
