Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 08-30-2013, 10:53 PM   #1
WEBBY1
WEBBY1's Avatar
patch pannels
ive been looking at brothers.... im guessing i can use a floor pan from a 65 c10 truck for my 65 suburban? also what about the wheel arches from a fleet side? do "you" recommend using their cheap floor pan or the high dollar? im also looking to purchase rockers as well... anything i should consider while replacing rockers or floor? thanks in advance
WEBBY1 is offline   Reply With Quote
Old 08-31-2013, 06:49 PM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: patch pannels
check out my build, I have some good pics of the floor (build is in my signature) the pass. side floor is different on a sub where there is a step to access the rear seat.
I was able to use truck rockers, they are the same... there is a steel plate that is factory that is welded to the rocker and rear quarter panel.
short fleet wheel arch should work, but might require a little fab where the lip is welded to the inner panel on the sub (truck has no inner panel)
if needed I think the truck pieces will work on the pass floor, it just won't be "correct"
Old 09-01-2013, 01:04 AM   #3
Captainfab
60-66 Nut
Re: patch pannels
If you need to replace the outter floor/inner rocker, I recommend getting this piece versus the 2 seperate pieces. This makes it easier to keep things straight.
http://www.topbananaparts.com/driver...r-section.html
The passenger side could likely be modified to be correct for a Suburban/Panel
Old 09-02-2013, 08:14 PM   #4
WEBBY1
WEBBY1's Avatar
Re: patch pannels
I'm new to all this.... Think I'm going to get those rockers captinfab thanks guys.... I'm going to check out your build.
Old 09-30-2013, 08:13 AM   #5
WEBBY1
WEBBY1's Avatar
Re: patch pannels
http://www.topbananaparts.com/driver...ker-panel.html for the outer? And this for the inner
http://www.topbananaparts.com/passen...r-section.html
Old 10-01-2013, 01:39 AM   #6
Captainfab
60-66 Nut
Re: patch pannels
Yes those are what I would use.
Old 10-01-2013, 06:27 AM   #7
WEBBY1
WEBBY1's Avatar
Re: patch pannels
thanks captain...
