Old 09-02-2013, 08:44 AM   #1
NC_John
NC_John's Avatar
Static Drop Spring Question
I want to do a down-and-dirty (read: CHEAP) drop just to make blu look a bit cooler. Long term plans are spindles or bags but with it needing so much other stuff right now and my budget already destroyed, I just need to get it lower.
Can I simply install the mcgaughy's 2" drop front and 4 or 5" drop rear springs? (I don't want to cut springs, as inexpensive as these ones seem to be) Will I be able to get any kind of alignment without dropped spindles or have any clearance issues in the back? I expect I'll need to get a shock relocator kit for the rear (it needs new shocks as well so I'll just get a set of AC Delcos for now). Its not a daily driver so I can live with losing some ride quality.
Seems to be the least expensive way for me to at least get out of the nosebleed seats for now.
Any issues?
Thanks!
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 09-02-2013, 08:51 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Static Drop Spring Question
2" front and 5" rear is a good plan if you plan on using drop spindles later.
But the front will be higher now.
You will also need an adjustable rear track bar for the rear.
I suggest www.earlyclassic.com for parts.
Keith
Convert to disc brakes.
Old 09-02-2013, 09:45 AM   #3
NC_John
NC_John's Avatar
Do you mean the front will be higher than the rear with the 2" front 4/5" rear until I get drop spindles? That might encourage me to expedite the spindles then.
I assume you mean the adjustable panhard bar?
Thanks!
1970 C-10 LWB "Blu"
Old 09-02-2013, 10:04 AM   #4
lolife99
lolife99's Avatar
Thanks!
yes and yes.
Keith
Old 09-02-2013, 10:28 AM   #5
slow-1
slow-1's Avatar
From my study's of the subject, I am going to do a 2/4 drop on mine...all of the pictures I've seen of 2/4 drops the truck sits level...with a 2/5, the rear is gonna be lower than the front.
1972 Cheyene C-10 "Ole Green"
My Grandfathers truck (early 70's to 1983)
My first vehicle (1983)
Original 350 (3 rebuilds)
700R4 from Bowtie Overdrives
slow-1 is offline   Reply With Quote
Old 09-02-2013, 06:12 PM   #6
NC_John
NC_John's Avatar
yes and yes.
nuts! well heck with that!
I guess that is what I'll do for now too. Then add spindles in the front and blocks in the back later to get a bit lower....
Thanks guys.
1970 C-10 LWB "Blu"
Old 09-05-2013, 10:41 AM   #7
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Cut 1 coil in the front springs
Install a drop block (2") in the rear from forum vendor ($60)
John
1999 Toyota Tacoma 4x4
Old 09-05-2013, 11:34 AM   #8
oldblue1968chevy
http://67-72chevytrucks.com/vboard/s...454824&page=11
Where i bought mine
John
Old 09-06-2013, 10:49 AM   #9
NC_John
NC_John's Avatar
Sounds inexpensive enough... what will that give me, a 2"/2" for now?
1970 C-10 LWB "Blu"
Old 09-15-2013, 02:28 AM   #10
oldblue1968chevy
Yes, 2" block in the rear and roughly 2" in the front. Wished I had a better pic I shot that after the truck was sitting for 8 months while I was..gone...
I have nicer pix on flat concrete but its 'stock' height in those.
John
Old 09-23-2013, 09:26 PM   #11
67ctener
67ctener's Avatar
2" spring and 2" spindle and in my opinion sits way too high. I think I got something weird just hope it's not the spindle
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
67ctener is offline   Reply With Quote
