07-06-2003, 09:53 PM | #1 |
Hootis is as Hootis does...
Which Turbo 400 to install????
I'm finally ready to replace theh old powerglide with a turbo 400. The motor is going to be a 383 with heads, cam, headers, etc, so have decided to go with the brute.
Question - I know that all 400's are not the same. Which one should I look for? and what should I expect to pay for one? Suggestions on where to get one, what model, etc are all appreciated!! TIA!
67 C10 LWB Fleet, 383, TH400, PS, 4BL-Holley, Headers & 3" Exhaust, 3" drop front, 4" rear springs, ECI shock relocate, Panhard Bar kit, wheels & tires 1995 Z28 Convertible - Borla, K&N, Lingenfelter Motor, C6 Wheels & Tires 1990 2500 4x4 Suburban 3" Catbac System, K&N, 2" Lift, Wheels, Tires |
07-06-2003, 11:35 PM | #2 |
I have a '72 400 turbo for sale. $100 + shipping
1957 Cameo |
07-07-2003, 02:48 PM | #3 |
Any idea of shipping costs? Which kind of 400 is it? Thanks.
07-07-2003, 03:28 PM | #4 |
its all about the +6 inches
As far as I know, a 400 is a 400 with the exception of tail shaft length.
Please some one correct me if I am wrong. |
07-07-2003, 03:43 PM | #5 |
I too have always thought there was only one except for the tail shafts.
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
07-07-2003, 05:39 PM | #6 |
Guest
Posts: n/a
Thats depends if you want one from a Chevy, buick, or a few others I thought. I cant be for sure, but I thought there are more then one kind out there...... But aren't they still going to be the same?
07-07-2003, 06:02 PM | #7 |
Only the bell housing area of the casting is different on the Olds, and Buick to accomodate the engine design. All internall dimensions are the same. The ones that came from the factory behind the hi-perf engines, did have different clutch packs with more plates in them. Any of them can be upgraded to the better clutchs. -
69 GMC K10 ..some restoration required....still.. |
07-07-2003, 06:18 PM | #8 |
Inline 69
i guess if you want to upgrade it, you could go with an aftermarket torque converter,&shift kit
07-07-2003, 06:29 PM | #9 |
Well, I was ignoring the BOP bellhousing, the Chevy bellhousing was te odd ball in GM, Buick, Olds, pontiac, and Caddy all shared one, and chevy had another.
07-07-2003, 06:34 PM | #10 |
There's some considerable differences in the older 400's ('65) that you probably won't find anyway. There are some subtle differences with the TH400s that came in trucks and cars between 1968 and 1980 in the valve body, the governor, some clutch components, and the modulator design.
Bottom line. If you get one out of a chevy truck (67-72) you're good to go.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
07-07-2003, 11:43 PM | #11 |
"Ochre Ogre"
Have you totally tossed out the idea of a well built th350? It is a no brainer swap since you only have to bolt it in and go. No drive shaft to change and no crossmember to move, shift linkage is identical and no kick down switch to wire in. The other benefit is you will get more HP to the rear wheels with a little less weight to boot. I have been told you loose 10-20 hp with a th400 compared to a th350. Just an idea..........
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
07-08-2003, 01:46 AM | #12 |
THE QUICKER FIXERUPER
The only diffrence I know of is pre 69 models had a diffrent filter.
07-08-2003, 03:58 AM | #13 |
gangforward where is jackson? zip code? It is a stock shortshaft out of a 1972 c20
1957 Cameo |
07-08-2003, 08:24 AM | #14 |
the Cady version 69-71 actualy had strait cut planetary gear in it the model was the th475 version.
07-08-2003, 10:00 AM | #15 |
Jackson, Wyoming - I'm planning on a pretty stout 383, with the idea I might put either a vortech supercharger or turbo's on it someday...
So I figured a T400 was the way to go.
07-08-2003, 12:36 PM | #16 |
GMC JUNKIE TOO: You're thinking about 400's from '65. Not only are the filters different, but the pan and the valve body are different (pan is identifiable due to bulge to accomodate the can style filter). The front pump is also different in that year - plus the torque converter didn't have fixed stator blades. There are also differences in the governor, clutch drums, sprag clutches, etc. As I said considerable differences, but you'll have a hard time finding one of those anyway.
Since cases are radically different from maker to maker (and so are the tailhousings: there are three different types, but interchanged between makers) chances are you wouldn't want to interchange hard parts anyway (without knowing a hell of a lot about 400's), so as long as you end up with a transmission with a Chevy case (the classic triangle shaped bell housing) you shouldn't have to worry about the planetary assemblies, clutch packs, input/output shaft differences. Just make sure it came out of a Chevy truck.
07-08-2003, 02:03 PM | #17 |
as far as the 400 is a 400 is a 400 question,
hot rod magazine had an article several years back about adapting a buick, olds or pontiac turbo 400 to a chevy block. it used 2 small fabricated adapters at the top. it seems that the line up pins are already in the correct place as are the bottom 4 bolt holes. the article cautioned about using one from a buick because they used a weird dual pitch torque converter. (please note, i have not tried this myself, but i do know of a friend of the family who did, although he passed away several years ago.) but i guess that it all comes down to the long or short tail version.
i survived cancer and kidney stones, but my kids are killing me. |
07-08-2003, 03:49 PM | #18 |
CCRider
I pretty sure the 475 was a motorhome transmission...I have one in an 84 pathfinder...it looks just like a 400
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
07-08-2003, 03:56 PM | #19 |
Cantankerous Geezer
beautimus, you're right. The lower bolts and pins are the same. I used to help with putting together demo derby cars. We would bolt them together, then make some hold-down tabs for the uppers. For some reason, we werent' to concerned about how long it would hold together!
Fred There is no such thing as too much cam...just not enough engine. |
07-09-2003, 07:39 PM | #21 |
Fabricate till you "puke"
Andy, the 425 hydro was a front drive trans. The 475 was found in the motor homes, & step vans. The 475 is basically a "tough 400 turbo(extra clutches, & straight cut planetery gears ..... a little whine in the lower gears(me likes that ) crazyL rowin 6
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
07-09-2003, 08:15 PM | #22 |
The only 475 I have ever heard of was in the Front wheel drive GMC motor homes.
And when that site said the TH 475 was a HD front wheel drive tranny, i figured it was right. Cool, thanks. |
07-09-2003, 08:41 PM | #23 |
Yup, I bet thats "square" . The GMC front drive motorhomes no doubt had the heavy trans. The Eldo & Toronado were a 425 hydro(just a twisted version of the 400). I wish I had more info on the 475T, I think I have 1 on the floor. The tell tale is the 6 lug allison converter. i havent opened the thing up to check the rest of the "goodies" tho crazyL
