09-04-2013, 10:40 AM | #1 |
Very slow/ not working turn signals
I finished up installing my factory wiring harness. I noticed my turn signals blink very slow and sometimes it will take 20 or 30 seconds to start blinking. Do I have a ground that I am missing? I have a new taillight harness and have all the grounds connected to clean metal.
09-04-2013, 10:47 AM | #2 |
Re: Very slow/ not working turn signals
Have you checked your bed to frame ground?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
09-04-2013, 11:11 AM | #3 |
each and every light bulb needs a ground in order to work
09-04-2013, 12:14 PM | #4 |
I have the grounds from the headlight plugs and front marker lights to the radiator support. The rear side markers ground to the mounting screw. I do not see a ground out side the brake lights. I did not clean the tail light housing where it mounts to the bed. I do belive the wiring has its own ground? I do not have a ground from the bed to the frame. I will add one or two?
09-04-2013, 12:24 PM | #5 |
One with 12 gage wire will be fine, you also need on from cab to frame and core support to frame. I also run a short negative battery cable from a starter bolt to the frame.
09-04-2013, 12:46 PM | #6 |
Cluster King
How fast is the wiper motor. Does it go slow also? I had this problem and it was caused by low voltage. Do you have a DVOM to check battery voltage?
Another way to test the theory is to use jumper cables on the battery from another vehicle while they are both running and see if the signals flash faster. |
09-04-2013, 12:59 PM | #7 |
I have not been able to get the wipers going yet. I turned them on and nothing happened, I have not had time to look in to that problem yet.
looks as if I have some ground wires to install. I will try that and see what happens. Thanks, Wes |
09-04-2013, 01:05 PM | #8 |
body of light bulb to body of socket GROUND
body of socket to taillight bucket GROUND taillight bucket to sheetmetal of bed GROUND sheetmetal of bed to frame GROUND frame to battery neg terminal GROUND for best operation all should b bright and shiny metal to metal contact and for good luck and long life a smear of dielectric grease to finish it off each and every light bulb sjhould be addressed in this manner fer the lights to work
09-04-2013, 01:28 PM | #9 |
Also, check your flasher. If that is bad, turn signals will not work.
09-04-2013, 04:16 PM | #10 |
That was the first thing
