09-04-2013, 03:26 PM | #1 |
"Trucks with Class"
What year diffs fit a 72 3/4T?
I couldn't find the answer. Can anyone tell me/us what later/other year front diffs will bolt in & go? 72 3/4T. thanks, frank
09-04-2013, 09:23 PM | #2 |
Re: What year diffs fit a 72 3/4T?
71-87. 88-91 in V series. Obviously 3/4 ton or 1 ton to keep your 8 lug bolt pattern. Dana 44 up until 1980 or so then 10 bolt. The K30/V30 had the Dana 60. 4x4 K30 first came out in '77 if memory serves. 60's bring almost 5+ times the $ a 44 or 10 bolt sells for. You may need to use a conversion u-joint and the 60 might need a little lift to get the driveshaft with enough clearance.
09-05-2013, 02:39 PM | #3 |
"Trucks with Class"
Good information---thanks a lot.
09-07-2013, 01:13 AM | #4 |
If you use a single wheel 1 ton 14 bolt ff out of a 70's or 80's chev, it will bolt right in without moving the perches. Just sayin....
09-08-2013, 08:49 PM | #5 |
He said front. But yes, one ton '73 and up has 40.5" spring centers just like '67-'72 4x4. All others '73-'87 have 42.5" same as 2x4 '67-'72. Shock mounts need to be changed regardless.
