Old 09-06-2013, 07:00 PM   #1
gtbdr
axle swap in 67 pick up..?
hi , im doing a 67 chevy pick up and have a dana 60 8 lug rear end and want a 5 lug, can I swap out shafts, ? or put in a different rear axle, what will work..
gtbdr is offline   Reply With Quote
Old 09-07-2013, 09:04 AM   #2
gtbdr
Re: axle swap in 67 pick up..?
.. anyone
Old 09-07-2013, 02:45 PM   #3
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Is your truck a 2WD, 4WD, coil sprung or leaf sprung? That info is needed to figure out what axles fit. (And helpful in any future posts for quicker, better help).
Is your dana 60 a full floater? It most likely is, so swapping hubs to 5 on 5 is doable but pricey.
The easiest would be to swap out entire rear axles with another truck. But to recommend axles we need more info about your rig.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 09-08-2013, 09:17 AM   #4
gtbdr
its a 2wd , coil set up
Old 09-08-2013, 06:42 PM   #5
airdale94
airdale94's Avatar
If you don't want to fab mount pads you would need to find a 71-72 1/2 ton 5 lug with coil spring set up. That should mount right in. I sure would like to have that Dana 60.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 09-08-2013, 08:43 PM   #6
gtbdr
you got a 5 lug, ill trade ya.lol. but im in n.y
