Old 09-09-2013, 06:34 PM   #1
Gumby
Gumby's Avatar
Anyone into wood working or?
Ive seen them guys on weekend TV shows take a router and trim down a wood edge.
surley it owuld be done in plastic?
is there a bit that can take some 3/16 plastic, and turn the edge down to 1/8, only needs to be about 1/2 wide area turned down, rest of it can be 3/16
morons at moms work put lexan in her broken sun roof, but didn't size if for the seal to work.
Gumby is offline   Reply With Quote
Old 09-09-2013, 06:42 PM   #2
DPowers
DPowers's Avatar
Re: Anyone into wood working or?
Rabbet Bit
http://www.pmcrouterbits.com/
DPowers is offline   Reply With Quote
Old 09-09-2013, 06:52 PM   #3
Gumby
Gumby's Avatar
can you show me which one or link to one that will do that?
sort of lost at this
Old 09-09-2013, 11:51 PM   #4
Zach B
Zach B's Avatar
The problem with plasic is it melts. Yes it can be done but you have to know how to cool it as you do it.
Zach B is offline   Reply With Quote
Old 09-10-2013, 08:46 PM   #5
DPowers
DPowers's Avatar
Here is the link to the bit that you would use. Your local hardware should have it. You will need a router however. Lexan should be hard enough that it wouldn't melt. I would try a scrap piece first though.
http://www.pmcrouterbits.com/router-...outer-bit.html
Old 09-12-2013, 08:37 PM   #6
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I would try a rotary saw.They're like a router but usually easier to control.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
