Old 09-13-2013, 02:06 PM   #1
bsealy
205 transfer case
i have a 72k/5 blazer i can not stop auto transmission fluid from going into transfer case transmission shop has pulled it twice and replaced seals in the adapter plate and o-ring on the shaft and this didnot stop it. can anyone help me with this problem.
bsealy is offline   Reply With Quote
Old 09-13-2013, 03:13 PM   #2
Dale99
Re: 205 transfer case
Check the inbetween shaft thats goes with the adapter/mount. See if it has groves in it.
2008 Sierra k3500 LMM
1994 s10 blazer 4x4
1991 Camaro Vert Rusted in Half RIP
1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364
1967 C10 L6/3tree(dads truck)
Dale99 is offline   Reply With Quote
Old 09-13-2013, 07:16 PM   #3
bsealy
are you talking about the sleeve if so its ok.
Old 09-13-2013, 08:27 PM   #4
Dale99
No, there is a double ended female "driveshaft" that rides between the trans and tc. It is basically inside the adapter. It could have deep groves in it causing it to leak. But there are even other issues before that, that need to be addressed as well. Fluid shouldn't even be getting that far. But this is something an average diy'r could look/fix.
Old 09-13-2013, 09:09 PM   #5
bsealy
what issues need to be adressed?
Old 09-13-2013, 09:39 PM   #6
Dale99
there are more seals up inside the transmission. There are ATLEAST 2 seals I know of(and i'm just now getting into 4x4) that keep trans fluid out of TC.
Old 09-14-2013, 05:16 PM   #7
DANTES JIMMY
DANTES JIMMY's Avatar
I agree if fluid is getting to the rear seal of the tranny
you may have more than just the rear seal
the rear seal isnt much of a seal kinda there just to keep back a little
DANTES JIMMY is offline   Reply With Quote
Old 09-23-2013, 08:31 AM   #8
smith
smith's Avatar
I've had 2 of these trucks and have had the same issue with both. Still debating on what to do right now since I still have this problem also. I wasted $500 on a rear output seal only to have the same problem again so I've got to get it fixed right this time...
Dan Smith
1971 Jimmy
smith is offline   Reply With Quote
Old 09-25-2013, 01:12 PM   #9
bsealy
there is no rear seal on a fourwheel drive automatic transmission.
Old 09-25-2013, 01:42 PM   #10
smith
smith's Avatar
Sounds like I may have gotten ripped off in the past, but whatever they did seemed to fix the problem for a little while anyway, but that was years ago.
I guess here's my ? then since I don't think this is something I can do myself. I've talked about it a little with the local 4 Wheel Parts guy but haven't gotten into detail.
What do I need to tell them so I don't have to deal with it again and to make sure all of the seals in the trans get replaced? Or do I need to try and find a transmission shop that works on older stuff?
Thanks.
Dan Smith
1971 Jimmy
