Old 09-15-2013, 07:41 PM   #1
FLDBRED
Fuel Pump, stock vs. HP ?
I noticed today that my fuel pump is leaking, so it's time for a new pump. Is there any benifit to a high performance pump or should I just go to NAPA and get a stock replacement? The motor is stock, just intake and carb.
FLDBRED is offline   Reply With Quote
Old 09-15-2013, 07:46 PM   #2
TBONE1964
Cluster King
TBONE1964's Avatar
Re: Fuel Pump, stock vs. HP ?
In your case, I would just use a stock replacement pump. Unless you have tons of horse power and an 850 or larger CFM carb, a stock pump will do just fine. The carb only needs around 5 - 6 psi of fuel pressure to function correctly.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 09-15-2013, 09:26 PM   #3
67ctener
67ctener's Avatar
I have an oe replacement on 402 with a 770 and it does great, doesn't quite sip the fuel either
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
67ctener is offline   Reply With Quote
Old 09-18-2013, 06:57 AM   #4
FLDBRED
Thanks for the responses, stock it is then. Should I get a GM replacement or is the auto stores ok ?
Old 09-18-2013, 11:02 AM   #5
In The Ten Ring
Not to hijack the thread, but before he does this, is it a good idea to go for an electric fuel pump or stick with mechanical? I heard an electric pump saves about 3 horsepower.
In The Ten Ring is offline   Reply With Quote
Old 09-18-2013, 02:56 PM   #6
cdowns
cdowns's Avatar
the originals last 40-50 years on a regular basis
electric for a carb engine is a great way to manufacture service problems where none existed
Old 09-18-2013, 03:10 PM   #7
67ctener
67ctener's Avatar
Mines a stock shucks replacement
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
Old 09-18-2013, 03:50 PM   #8
In The Ten Ring
cdowns,
You are probably on to something there and the main reason I haven't bought one....that and wiring is something I have little experience with.
I bought a new mechanical fuel pump at Advanced Auto but I have not put it on. My truck still has the original it came with. Should I swap it out?
Old 09-18-2013, 06:24 PM   #9
FLDBRED
I am going to try to get a GM service replacement, I think Classic Industries has them. It's hard to ignore 40 - 50 years of service!
