Old 09-17-2013, 06:25 PM   #1
In The Ten Ring
Never gets easier!
Hey ya'll,
I caught a break today, all of an hour, and worked on the truck some. I grinded the spot weld down a bit where the front cab bushing bolt goes.
ALAS, there doesn't seem to be enough room to use the washer that came in the kit! If I use it, the bolt head will stick out above the level of the cab floor. I know there was no washer used here originally but I like washers! Who has run into this and what did you do?
*I still have more grinding to do....tight space even for a dremel tool.
In The Ten Ring is offline   Reply With Quote
Old 09-17-2013, 07:57 PM   #2
Syndrome
Re: Never gets easier!
Grind the bolt head down so its not as tall. Don't let it get hot though. lol
1970 GMC
Syndrome is offline   Reply With Quote
