6" rear spring or airbag?
I am trying to get my rear to set correctly. I am running 20" and 22" coys with 2.5" spindles with 2" front coils. Currently in the rear i have 5" coils and 1.5" blocks. WIth the larger wheels in the back it has a little too much rake for me. I am trying to decide weather to put 6" coils in the rear or a schrader air bag setup? any suggestions on who to buy coils or airbags from?
Re: 6" rear spring or airbag?
I went with bags with schader valves.Its totally adjustable.I drilled holes though the frame for mounting holes and a hole for the air fitting.So the bag is touching the arm and the frame(short as possible).With the blocks you will need a frame notch.I need the bolt in notch and Im not even using blocks.
Posted via Mobile Device |
Where can I buy a Schrader bag setup?
2WD Jimmy
![]() Join Date: Mar 2005
Early Classic Enterprises has the perfect bag setup for you.
