Old 09-18-2013, 01:43 PM   #1
RPBurris
RPBurris's Avatar
What tank do I have?
Below are some pics of the tank that is rear mounted in my 69 K20. I should note the frame is a 78. At least I think it is.... Anyway the tank does not look like anything in the LMC catalogs and I want to order a new fuel pickup and straps. The tank itself is in good shape. The existing pickup has vent lines and such for a charcoal canister that I am not using. You can also see how deteriorated the rubber fuel line was. Yikes. It has been years since I filled it up and only dropped it so I could empty the few gallons that were still in there. The filler goes to the passenger side of the bed. Thanks all for your help!
1969 Chevy K20 Longbed
RPBurris is offline   Reply With Quote
Old 09-19-2013, 10:13 AM   #2
RPBurris
RPBurris's Avatar
Re: What tank do I have?
Anybody??
Old 09-19-2013, 11:46 AM   #3
Livrat
Member #1049
Livrat's Avatar
it looks to be a mid-late 70's Blazer or Burb tank
Livrat is offline   Reply With Quote
Old 09-19-2013, 01:42 PM   #4
snj8198
snj8198's Avatar
The last time i pulled a tank that looks just like your pic with that many vents and a return it came from a 1989 diesel suburban.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 09-19-2013, 02:11 PM   #5
67 cst swb
67 cst swb's Avatar
Is it approx. a 40 gallon tank? is so, I may be able to help.
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 09-19-2013, 02:47 PM   #6
aedcustoms
aedcustoms's Avatar
Here is one out of an 87 burb I parted, 40 gallon
Sending unit a little different bc it was tbi
1969 C10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=580422
1981 C10 SWB
1995 ECSB Bagged
aedcustoms is offline   Reply With Quote
Old 09-20-2013, 06:36 PM   #7
RPBurris
RPBurris's Avatar
So I guess it is looking like a 40 gallon diesel tank? At least now I know and LMC does have pictures and even dimensions in there catalog. I guess it helps to flip to the 73-87 section if my frame is a 78....
40 gallons...I am never going to fill that up.
