09-19-2013, 11:35 AM | #1 |
Brake Pedal Ratio for a 1967 with factory brake pedal?
Okay i need to know the Brake Pedal Ratio for a 1967 chevy truck. Mine is torn apart and I need to know the Brake Pedal Ratio in order to figure out what Master Cylinder to run with my Z06 brake calipers.
Thanks in advance.
Project "Edna Marie"http://www.67-72chevytrucks.com/vboa...74#post5998074 Toys: 2014 Dodge Ram 1967 SHORTBED |
09-19-2013, 11:53 AM | #2 |
Re: Brake Pedal Ratio for a 1967 with factory brake pedal?
Should be 6 to 1. Measure it! Full length divided by distance from top to pushrod hole.
09-19-2013, 12:28 PM | #3 |
My brake pedal is not in the cab or I would (-;
09-19-2013, 12:34 PM | #4 | ||
It probably depends too on if your truck was originally power or manual brakes. I don't have anything for '67, but I do have the brake system release charts for '74 and for '87. Scan through there to get a feel for the numbers. http://67-72chevytrucks.com/vboard/s...d.php?t=510519 Looks like most of them are around either 4.5:1 or 6:1. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
09-19-2013, 12:37 PM | #5 |
Thanks for the help!!
09-19-2013, 12:46 PM | #6 | |
While you're at it drill another hole 1 1/2 inches below the other pushrod hole. It's needed for power brakes because the ratio needs to change to 4.5 to 1. |
09-19-2013, 01:00 PM | #7 | |
