09-19-2013, 07:21 PM | #1 |
Defrost hoses.
I got some new defrost hoses a while back, there real sticky material and i'm having a bit of a time getting them slid over the heater box outlets and plastic vents.
I don't know what this material is but i am looking for a way to lube them up so they slip on instead of fighting them but not so badly that they will pop back off on there own. After i got these i found out that there are 2 different typed of material used so maybe i should have gotten the other stuff??
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
09-19-2013, 07:37 PM | #2 |
Re: Defrost hoses.
I have not run into this problem but If you lube the hoses they may slip on and then slip off. I would try a hairdryer and heat the hoses up a little before trying to install them.
If you do go the lube route and get them on, black electrical tape can be used to tape them to the tubes. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
09-19-2013, 09:02 PM | #3 |
Re: Defrost hoses.
i used heat and they always went on an stayed in place// you could try a little bit of water on the plastic cause it will not leave a residue
09-19-2013, 09:48 PM | #4 |
Re: Defrost hoses.
There not the plastic ones there like a sticky tar paper similar to the originals.
09-19-2013, 10:29 PM | #5 |
Re: Defrost hoses.
Can i ask, where did you get the hoses for the defroster? Can i get something similar from home depot or lowes? Gotta put some in my truck since for some reason the last owner decided that since the heater was gone and they put in a stereo that they didn't need to put them back in ----___----
09-19-2013, 10:32 PM | #6 |
Re: Defrost hoses.
Pm sent.
09-20-2013, 04:44 AM | #7 |
Re: Defrost hoses.
heater box and dash vents are plastic
09-20-2013, 07:49 AM | #8 |
Re: Defrost hoses.
I would try some black rtv silicone...slippery to install,and once it dries it will hold them on
1970 short step c10 leaf spring 454 |
09-20-2013, 08:56 AM | #9 |
Re: Defrost hoses.
I would suggest using talcum powder (baby Powder) to get the hoses on. It will limit the stickiness, but not provide lasting lubrication. Just be careful the first time you blow air through the tubes because there will likely be a cloud of powder. I used this method for the silicone heater tubes in aircraft.
1990 Suburban Silverado 350, SM465 and 35" tires |
09-20-2013, 03:19 PM | #10 |
Re: Defrost hoses.
If they have the metal spiraled wire in them rotate them like your turning a screw to thread onto the heater box outlets, then sick them through top opening of dash, I know its a stretch but they'll stick through the top and rotate the round vent on and then form the other hose to the oblong shape and by wiggly it some you can get the metal spiral past the tabs designed to hold it on. I generally pry with the nubs of my fingernails on the last oblong one. About a 5 minute install using this method.
Paul @ GMCPauls |
09-20-2013, 04:44 PM | #11 | |
Re: Defrost hoses.
I can give it a shot soon, right now my truck is still on jack stands on 4 corners and i don't wanna hop inside.
