09-20-2013, 11:09 PM | #1 |
Throttle Cable & Windshield
Hello Everyone!
I need an adjustable throttle cable and need some brand ideas. What are you using? Also, can I get a windshield locally? Any brands to avoid or consider? What about window rubber (with trim). Thank you! Heath Posted via Mobile Device
1971 C/10 - Orange & White 2009 GMC 1500 - Lowered 3/4 22' KMC Slides |
09-20-2013, 11:25 PM | #2 |
Re: Throttle Cable & Windshield
Can't help you with the throttle cable, but you should be able to get a windshield at any local glass shop. Call around though. I did and the price ranged from less than $200 to more than $600. The general consensus on the board is the Precision is the best brad for the window rubber. I bought one from GMC Paul for about $40 shipped.
Good lookin' truck!
Willie Swamp Angel Truckers '72 C10 Highlander People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. |
09-20-2013, 11:30 PM | #3 | |
09-20-2013, 11:46 PM | #4 |
2WD Jimmy
Go Pilkington on the glass, my son is a glazier and that's what he recommended.
Why do you need an 'adjustable' throttle cable? Posted via Mobile Device |
09-21-2013, 12:06 AM | #5 | |
I need an adjustable one so I can fine tune with my 700R. Need to establish full throttle and the LMC one does not allow that. Posted via Mobile Device
09-21-2013, 10:15 AM | #6 |
2WD Jimmy
OK... I cut the pedal end off mine and shortened it that way. I used a little (dont really know what to call it), but its a little screw clamp that we use in RC airplanes to shorten control cables (they are pretty much the same as the throttle cables in the 71-72 trucks) LOL but it works great. Want me to send you one?
09-21-2013, 02:34 PM | #7 | |
09-21-2013, 02:57 PM | #8 | |
09-21-2013, 05:56 PM | #9 |
No. I don't think so.
09-21-2013, 09:20 PM | #10 | |
The Older Generation
Just make sure you get the correct rubber seal for "your" trim. There are two different ones. LockDoc
09-22-2013, 11:54 AM | #11 | |
Sam >> http://www.bowtieoverdrives.com/cata...SUBCAT&CATID=W << |
09-22-2013, 10:25 PM | #12 |
Pilkington glass, and Precision rubber! Can't go wrong. .02
09-22-2013, 10:36 PM | #13 |
Thanks for the info! Anyone find a windshield that does not have the blue strip across the top?
09-22-2013, 10:52 PM | #14 |
They come in clear, tinted, or shaded. Just specify which you would like. Tinted is a factory light green tint, shaded is a tinted with a shaded strip, which generally came in vehicles with A/C. I prefer the shaded for the sunny days.
09-22-2013, 11:56 PM | #15 |
I just put a Spectre on mine. Works well. It is a cut to fit, handle it like steel braided hose when you cut it to fit. $20, worked well.
09-23-2013, 12:20 AM | #16 | |
Thank you! Posted via Mobile Device
09-23-2013, 12:47 PM | #17 | |
Shawn
-- '67 Chevy Stepside 250 Inline 6 Megasquirt Fuel Injection T5 5 speed conversion Ferric Oxide impregnation throughout |
09-23-2013, 04:38 PM | #18 |
Locar universal throttle cable will work too.....lots of adjustability & smooth operation. They are a bit pricey though..about $40 for the plain black cable one.
