Old 09-21-2013, 11:10 AM   #1
69StepsideMedic
Front cab mounts
Do they make the front cab mounts for the frame ?
69StepsideMedic is offline   Reply With Quote
Old 09-21-2013, 12:26 PM   #2
In The Ten Ring
Re: Front cab mounts
The cab has four mounting points: each receives 2 rubber bushings. You can use polyurethane ones if you like to feel every bump in the road.
In The Ten Ring is offline   Reply With Quote
Old 09-21-2013, 12:26 PM   #3
Lee H
Lee H's Avatar
Are asking about the rubber cushions or the metal frame bracket that holds the cushion?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 09-21-2013, 12:44 PM   #4
In The Ten Ring
Lee H,
That's a good question, sorry I missed it! We definately need more info here to give accurate advice.
Old 09-21-2013, 12:44 PM   #5
69StepsideMedic
Frame brackets
Old 09-21-2013, 01:37 PM   #6
chvtrkman
chvtrkman's Avatar
Hi, saw this question just before heading out the door...so the short and quick answer is, yes,the frame mount brackets are available.. I bought a pair for my truck as they were quite rusted.I found them on Brothers website..part # FM72CMR 67-72 cab support frame mount - rear. Hope this helps you.
69 C-20 292, 4 spd O/D, 4:56 rears. No a/c p/s p/b p/w......restoration project,"Operation:Stovebolt"
78 C-10 305 TH350 new (old) daily driver
02 Suburban Z71 a.k.a. the family truckster
99 Silverado 1500 Z71
chvtrkman is offline   Reply With Quote
Old 09-21-2013, 06:13 PM   #7
69StepsideMedic
It does thank you very much
Old 09-21-2013, 08:17 PM   #8
Lee H
Lee H's Avatar
Just getting back.....good answer.
