High Performance Rams Horns?
Anybody seen, used, or know anything about these?
http://www.ecklerstrucks.com/chevy-t...1947-1972.html Might be a good alternative to headers. Get a little better breathing but still look stock.
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
Re: High Performance Rams Horns?
Corvette manifolds, a pretty common swap. Let me see if I can find a thread with part numbers for you.
Edit: here's a little info for you http://67-72chevytrucks.com/vboard/s...ad.php?t=29073
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
#3 | |
I looked up the PN's on the thread and they were for the right parts but each side has those big mounting brackets for accessories.... GM PART #'s 3797901 / 3814970 The Ecklers might be a good option as they come without the mounting brackets IF they aren't too cheaply made (and prone to cracking).
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 Last edited by NC_John; 09-21-2013 at 09:27 PM. |
Buy them on Ebay for half that price.
1957 CHEVY 1/2 TON SHORT BED 1940 FORD 1/2 TON SHORT BED |
Old member
U don't want the straight down horns they will hit the motor mounts. U need the angled ones for the trucks.
Unless u plan on some custom pipe work. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
the problem is the angled ones are not avail in 2.5", no performance gain there. I've been told on this board that the straight down dump will fit.
Moderator
![]() Join Date: May 2007
Straight dump are for 4wd trucks
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
People with 2wd trucks have said they have them on their truck.
#9 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Posted via Mobile Device |
![]() Join Date: Aug 2003
I used them and used a starter from 89 truck. Need a good muffler man to do pipes right. Starter is shorter and smaller diameter.
