Old 09-23-2013, 02:16 PM   #1
Andrewb83
Andrewb83's Avatar
Removing tie rod
I'm trying to remove my tie rod. I thought I should just have to take the castle nuts and cotter pin out, and it pop out but no luck. I noticed there is a bleeder valve on the ends would I need to bleed that? Here is a pic
Thank you
Andrewb83 is offline   Reply With Quote
Old 09-23-2013, 02:19 PM   #2
Andrewb83
Andrewb83's Avatar
Re: Removing tie rod
Here is a pic Of the bleeder valve
Old 09-23-2013, 02:49 PM   #3
vidman
vidman's Avatar
thats not a bleeder valve...Its a zerk fitting. use a tie rod separator with a air gun or BFH.
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 09-23-2013, 06:05 PM   #4
Andrewb83
Andrewb83's Avatar
Bfh?what is a zerkfitting? I went to part source and got the ball joint separator tool , hopefully that works
Old 09-23-2013, 06:22 PM   #5
mmiddle
mmiddle's Avatar
A zerk fitting is for a grease gun chuck to lube the joint.
Some times you can get lucky and hit the stud end of the tie-rod with a large hammer (BFH). Do this with the nut on the threads, just loose.
Other wise you will need a "pickle fork" or tie-rod separator tool to remove the tie-rod stud from the tapper.
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 09-23-2013, 06:41 PM   #6
Andrewb83
Andrewb83's Avatar
Aww bfh duh, I got the tie rod separator so ill give those a try other wise ill grab a mini sledge and have at her
Old 09-23-2013, 07:26 PM   #7
LONGHAIR
Are you removing the tie-rod to replace it? Or for some other reason?
If you separate it with a "pickle fork" type tool, it will destroy the boot....then you will be back here asking where you can buy the boot.
The best way to separate it is to loosen the castle nut (not remove) then apply some pressure against the tie-rod with a pry bar and smack the housing itself right next to the the tapered stud. Do not hit the stud itself or the nut, you will just damage the threads.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 09-23-2013, 07:50 PM   #8
Andrewb83
Andrewb83's Avatar
I'm during a full Reno so I'm taking it off to sand and powder coat. I guess I'll try finess first before prying. Partsource has another pry kit that is more like I clamp with a bolt in the middle. It's supposed to slowly push the bolt up. Think that's a better option then the prong pry kit
Old 09-23-2013, 09:19 PM   #9
mongoose
mongoose's Avatar
if you're doing a reno on it just pound it out... and replace it.. they are cheap.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 09-23-2013, 09:30 PM   #10
Andrewb83
Andrewb83's Avatar
Awesome thanks for the advice everyone
Old 09-24-2013, 03:29 AM   #11
andrewmp6
And make sure your wearing safety glasses when hammering on it just in case something chips and flys off.
andrewmp6 is offline   Reply With Quote
