Old 09-26-2013, 10:12 PM   #1
Ackattack
Ackattack's Avatar
Spark plug problem
Where are the spark plugs on a cummins, I can't find them
Ackattack is offline   Reply With Quote
Old 09-26-2013, 10:58 PM   #2
clinebarger
Re: Spark plug problem
Troll
clinebarger is offline   Reply With Quote
Old 09-27-2013, 09:32 AM   #3
dieseldude4bt
here http://www.emacsz.com/uploadfiles/engine.jpg
63 k20 with cummins 4bt, owned sence 1982
dieseldude4bt is offline   Reply With Quote
Old 09-28-2013, 06:41 AM   #4
brimc
brimc's Avatar
Aren't they attached at the end of the spark plug wires.
BRIAN
1986 Chevrolet K20 Silverado 12 Valve CUMMINS P Pumped Intercooled/Getrag360/Divorced NP205/10B/14BFF Detroit Locker - DD Canadian Winter Beater.
My Chevrolet CUMMINS Build http://67-72chevytrucks.com/vboard/s...d.php?t=585509
brimc is offline   Reply With Quote
Old 09-28-2013, 12:52 PM   #5
ERASER5
ERASER5's Avatar
In a box behind the seat? That's where mine are, at least until I get home.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 09-28-2013, 01:28 PM   #6
jjzepplin
jjzepplin's Avatar
I keep them in a van down by the river
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 09-29-2013, 10:54 AM   #7
meatwagon83
meatwagon83's Avatar
they are between the blinker fluid reservoir and the kaneuter valve
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 09-29-2013, 08:47 PM   #8
Ackattack
Ackattack's Avatar
Kaneuter valve? I thought diesels only had muffler bearings!
Old 09-29-2013, 08:51 PM   #9
72chevyk10
I built it
72chevyk10's Avatar
no muffler bearings. just piston return springs.
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
Originally Posted by prostreetC-10 View Post
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 12-19-2013, 11:06 PM   #10
1972RedNeck
1972RedNeck's Avatar
You have to take the Johnson rod off with a left handed screw driver (metric of course). Make sure to run hollow spark plug wires.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 12-19-2013, 11:21 PM   #11
DPowers
DPowers's Avatar
Is it a vette motor?
DPowers is offline   Reply With Quote
Old 12-20-2013, 02:18 AM   #12
84chevyguyid
While changing spark plugs always check for a cracked maniform...
84chevyguyid is offline   Reply With Quote
Old 12-20-2013, 02:08 PM   #13
Bigdav160
Bigdav160's Avatar
They are under the coils
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 01-25-2014, 12:25 PM   #14
superduty_59
This Cummins does have spark plugs! It's a Cummins Westport.
superduty_59 is offline   Reply With Quote
