crate engine bolt on ?'s...
Recently picked up a crate motor.it already had a stock style intake and stock manifolds in place.Its a gen 1 vortec crate motor , flat tappet cam.
Should i spend the $$ on an aluminum dual plane and a set of headers?? Is it worth the performance gain?? I think I'd be looking at around $400 for the pair. I have a comp cams xe model /liftets layin around. Worth opening up the motor and swapping out the stock flat tappet?? Or just leave all of it alone , throw a carb on it and call it good. Just trying to see what kinda difference in hp/tq roughly it'd be with all those items vs leaving it all as is. Thanks. Posted via Mobile Device |
The Older Generation
Re: crate engine bolt on ?'s...
Personally I don't think the gain would be worth the pain. Of course I'm old and old school, so I don't really give a crap about all that horsepower stuff any more... ![]() Just my 2¢ worth. LockDoc
![]() Join Date: Jul 2013
You can do that and it will help somewhat. However, in my experience the low-end create motors have really crappy intake ports on the heads. Running a bigger cam and intake only make this more evident. It will run fine under normal idle to 4500 or so, but fall flat after that. You will notice improved power to 4500 maybe 5000. You will also notice little better fuel milage.
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
I think this crate motor may be in the 250-260hp range . Plus its not a performance vehicle its a truck and I'm on a budget so ill leave it all alone just throw a nice aluminum dual exhaust with a bassani x pipe and call it good. I'm sure that will be a huge improvement over the rusted out tiny diameter steel exhaust it had.
I live where it gets hot 100 degrees or above sometimes in summer. Should I opt for a 3 row radiator ?? The other radiator looks to be the factory one and the truck had sat a long time prior to me buying it. Dont want to risk the crate motor getting messed up.already picked up a new water pump, thermostat but want to do the radiator as well. Just for peace of mind :') Posted via Mobile Device |
![]() That was a trial fit of the old dynomax longtubes off my old 69 camaro, didn't work . Spent the $$$ and upgraded to ece power disc brakes for the front.kinda excited , never had disc brakes on any of my old cars over the years. Also picked up a powdercoated ece crossmember for the 700r4 , overdrive should make it great for daily driving.where I live I gotta jump on the freeway/highway frequently Posted via Mobile Device |
#6 | |
![]() Join Date: Mar 2012
i had a problem with overheating and white sludge in a new crate engine, after i sent it back twice and a million pictures during tear down and installation ect ecct, they finally replaced the whole thing with a another engine, it took me about a year to get it straightened out finally, but they did everything they could to make sure it was not something i caused,
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
#7 | |
Thanks mike, ill mention the drilling of thermostat to my mechanic.
My 69 camaro seemed to be reliable with a 3 row and a flex fan/shroud setup. Posted via Mobile Device |
