Old 09-27-2013, 03:12 PM   #1
Roger 555
Install newer alternator on 1970 GMC
I'm putting a 89 Corvette engine in 70 GMC. Old alternator had the old style voltage Regulator. My wiring diagram shows the brown wire from the old regulator to the firewall plug but diagram does not show what this wire is going to. Need to know if this brown wire is going to my amp meter? And is it still brown coming out of the harness and goes to the amp meter connection on the PC board on the dash? 2nd question the blue wire coming off of the new alternator appears to need to go to a switched 12V?
Roger 555 is offline   Reply With Quote
Old 09-27-2013, 08:19 PM   #2
Superdrag67
Re: Install newer alternator on 1970 GMC
I just upgraded my alternator yesterday. These two links should have all the info you need.
http://67-72chevytrucks.com/vboard/s...ght=Alternator
http://67-72chevytrucks.com/vboard/s...d.php?t=119379
Superdrag67 is offline   Reply With Quote
Old 09-27-2013, 11:40 PM   #3
Roger 555
Thank you so much great information.
