09-27-2013, 05:38 PM | #1 |
Fuel sending unit okay, gauge not working?
I thought my sending unit was bad since my fuel gauge never moves. I pulled it and checked it with an ohm meter and it seams to be okay. What else could it be? The gauge itself? It worked when I got the truck, just stopped one day at 1/8 of a tank
married to TARA, that makes me the TARA-fied1 |
09-27-2013, 08:08 PM | #2 |
Re: Fuel sending unit okay, gauge not working?
Did you check the fuse for the dash gauge?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
09-27-2013, 08:27 PM | #3 |
Make sure wire for fuel gauge is still connected to fuse block
Kerry My build thread. http://67-72chevytrucks.com/vboard/s....php?p=3657823 1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears 1988 Chev Extendacab 2010 Honda VT1300CS Sabre 2005 Buick Rendezvous wife's ride |
09-27-2013, 10:07 PM | #4 |
I did check the wire and the fuse. I drove the truck to day and noticed the temp gauge wasn't working either. I had only visually checked the fuse and it looked okay, but it turns out it was bad. I changed it and the gauges started working again. Leave it to me to make something more complicated than it has to be!
THANKS!!!
09-28-2013, 09:48 AM | #5 |
The problem I've found more often than anything else is the ground. People test the sending unit at the sending unit, but the ground would still be bad. I would say out of a several dozen people that brought in cars/trucks with a "bad fuel gauge", only 2 or 3 were actually the gauge. Try testing the resistance between the unit and a ground point.
I stopped adding up how much I spend on my builds, it only makes me doubt my sanity knowing I've spent more than 9 times it's original value new.
