Old 10-01-2013, 06:58 PM   #1
asolde
asolde's Avatar
Door alignment help
I had my inner kick pnl patched, lwr A pillar patched,inner rocker pnl patched,part of the floor pan patched, floor support on the drivers side patched and replaced the outer rocker panels. I had this done to both sides with the drivers side getting most of the work. I had all this work done at body shop and I kept a close eye on it while it was being done and felt pretty good about the work, but dissapointed about it now.
I have two problems right now. The first problem is on both sides the lower hinge on the A pillar have one bolt spinning out of the three. I am not sure what the fix will be for this so any advice would be helpful. What ever the repair is I don't think it's going to be simple.
My second problem is the doors are way out of aligment with the passenger side being the worst one. I have purchased a door hinge wrench off of ebay to be able to get at the bolts with the fenders installed.
Here's a few pictures showing the door aligment and one showing the bolts that are spinning
asolde is offline   Reply With Quote
Old 10-01-2013, 07:11 PM   #2
67Steven
67Steven's Avatar
Re: Door alignment help
What does the vent wing to windshield area look like?
Looks to me as though the door needs to be rotated clockwise just a bit. This will bring the body lines back and clean up the gaps.
67Steven is offline   Reply With Quote
Old 10-01-2013, 07:55 PM   #3
asolde
asolde's Avatar
Here's my vent window. It looks tight up at the top.
